Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Opinions about the GEN8 PACK?
Old 02-28-2020, 11:33 AM   #1
Default Opinions about the GEN8 PACK?
Was thinking about purchasing it, is it worth it?
Is this a capable platform to use?
Do/did you like it out of the box?
Any upgrades to get before slapping on your gear?
Is/are there upgrades out of the box,or is it the same as their RTR?
Again many thanks!
Frank211 is offline   Reply With Quote
Old 02-28-2020, 02:18 PM   #2
Default Re: Opinions about the GEN8 PACK?
PACK is the chassis of the RTR Scout II (not AXE) less fenders, sliders and wheels.
First item to change is the provided servo horn by any generic servo horn ... that'll correct the bump-steer issue, replacing the skid plate is a matter of taste ... some can't drive with its bump, overs deal with it. Overwhise, out of the box, it's already pretty capable without any upgrades ... provided you don't over-power it and don't drive it like Slash.
One thing I regret on this chassis are the shock towers ... front and rear are different and protrudes a lot above the rails. Can be a pain with pickup bodies.
tuxstang is offline   Reply With Quote
Old 02-29-2020, 12:01 PM   #3
Great performing rc I really like mine
Sent from my SAMSUNG-SM-G890A using Tapatalk
jakemaxwell806 is offline   Reply With Quote
Old 03-02-2020, 09:41 AM   #4
The P.A.C.K seems like a pretty solid platform for $169. I was lucky enough to find a new Axe version of the P.A.C.K that was being sold on ebay for $189. The things people tend to want the most right out of the box are a flat transfer case skid on the bottom,upgraded portal gears,the new style portal housings, and the servo horn from the Axe to eliminate bump steer. However, even without the few upgrades it is quite capable. Oh and currently the RTR is only $100.00 more so that might be a more cost effective route in the long run depending on what you have to toss in the chassis kit.
Flamnpede1 is offline   Reply With Quote
Old 12-01-2021, 12:11 PM   #5
One thing I regret on this chassis are the shock towers ... front and rear are different and protrudes a lot above the rails. Can be a pain with pickup bodies.[/QUOTE]
Yes, I run a 93 f-series body from Jconcepts and ended up cutting holes in the bed for the shock towers. All in all, a very capable rig. I put a castle brushless system in mine, a few treal parts for front axle, and it's pretty set now.
Bronco 300 is offline   Reply With Quote
Opinions about the GEN8 PACK? - Similar Threads
Fitting the Pro-Line SR5 to a Gen8 PACK Elmo Redcat Crawlers 6 08-21-2019 12:46 PM
My Gen8 PACK-well, it was for a bit.... dungeonracer Redcat Crawlers 4 05-14-2019 09:33 AM
Opinions on this battery pack crawlmaxx Electronics 17 10-16-2005 06:14 PM
