01-14-2022, 07:07 PM | #1 |
Pebble Pounder Join Date: Oct 2004 Location: Central NJ
| Gen 8 V2 Scout mods
I've been out of the hobby for a few years but after "getting up to date" on the state of things (such as Vanquish and Associated are making crawlers now and Vaterra has vanished, for examples), this truck caught my eye. Wow, I like it a lot. Redcat has come a long way since the Rockslide XT and Everest 10 came out like 10(?) years ago. Kicked things off with better tires and heavier wheels... To compensate and add a little more air in wells the shocks were moved the lowest holes in the towers Noticed the rear wheels were little too far forward (as seen above) so the links were moved to the rear most holes. It sits nice, I think. Next up is checking for grease in the axles, shortening the battery tray for shorty's, gearing down a few teeth on the pinion and swapping out the radio and esc. Will see where it goes from there. Still can't decide which kit decal scheme to go with - they all look awesome! Anything else I should do at this point? . |
01-14-2022, 07:13 PM | #2 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: Gen 8 V2 Scout mods Get out and drive it... Upgrade what breaks I actually really like the stock swampers and they do lots better on a heavier wheel, with good foams. With a bit of break-in, they started working very nicely. I put CI dual stage in mine on the stock wheels and it was a marked improvement over the stock Redcat foams. |
01-14-2022, 09:02 PM | #3 |
RCC Addict Join Date: Jun 2008 Location: Mudville
I'd say you can take that rear axle back a few more mm even. 5 at the most maybe. If you trim the front bumper mount posts a bit shorter, you can get the front bumper a hole farther back and improve the approach angle. Same in the rear, but instead of trimming the mount post, you'll need to trim the bottom of the body just a smidge so the bumper can slip in one hole improving the departure angle a few degrees as well. The stock foams were meh on my AXE, got pretty firm in the cold. now they're ok, but they're twoish years used now. heh. Wheel and tires look good on it for sure. Stock tires are pretty decent with better foams. First, and so far my only breakage on my AXE was the drives side slider snapped. Replaced them with the KYX steel Gen8 sliders. The drives side knuccle steering arm got bent to shit, but it did take 4 to 5 months to get bent bad enough it was time to replace them. Went to some Treal gear from there. Treal Chubs and inner portal housings and a noname aluminum portal cover on the F and on the Rear Treal inner and outer portal housings to add some weight and balance the front and rear bias which is about 60/40 and almost damn near dead nuts even side to side. The Bodies are a bit top heavy and this AXE body is way top-heavy. She weighs in just under 11lbs right now. I upgrade the wheels and tires, added servo winch and reefs mount for it, full light kit. light bar and rock lights are about to go in. and finished up. One upgrade I would say is a required one is to get rid of the bump steer. Which is kind of significant. I did it with some SSD TK/SCX10.2 steering links and an offset servo horn of 10 - 12mm. with a little setup and some minor adjustment to get the toe right, it works great and there is pretty much zero bumpsteer now, even though there is still the hard panhard axle shift going on. Which I did minimize with the Bowhouse RC panhard chassis relocation mount and the SSD lower link mounts with both move the panhard mounts respectively and help a little bit with the shift, but mostly help get things in better positions to get rid of the bump steer. I agree. RedCat has come a LONG Ways from their break into the RC in the 5th scale world back in 08ish. Last edited by Timmahh; 01-14-2022 at 09:14 PM. |
01-14-2022, 09:09 PM | #4 |
Newbie Join Date: May 2021 Location: Sacramento
Off to a good start! I'm also recently back into the hobby, after a ~16yr break, and yes it's nice to see some quality, budget oriented crawler/trail trucks! I also recently got a Gen8, in purple, and I'm very impressed with it's performance so far. I've only added a light kit, and boiled the foams in the stock tires. Trying to avoid spending $$ on wheels and tires for a while, but I know that'll make a big difference. I've been thinking about budget motor/esc work, but now you've got me thinking about just gearing down the stock setup. I like the wheel speed currently on 3s, but would also like more modulation at creep speed.
01-14-2022, 09:22 PM | #5 | |
| Re: Gen 8 V2 Scout mods Quote:
HW 1080WP ESC and a Holmes Trail Master or Crawl Master would be a great combo I believe and run maybe 60-70 so not to cost and should be much better than the stock esc/motor combo. | |
01-15-2022, 08:14 PM | #6 |
| Re: Gen 8 V2 Scout mods |
01-20-2022, 08:16 PM | #7 |
01-21-2022, 03:33 PM | #8 |
Lookin good.
02-08-2022, 04:09 PM | #9 |
Newbie Join Date: Mar 2021 Location: Bel Air
Those sliders look nice! Who makes them?
02-08-2022, 05:18 PM | #10 |
Pebble Pounder Join Date: Jan 2021 Location: Germantown
02-08-2022, 06:20 PM | #11 |
on the v1 the ssd link mouhts were a must have upgrade i dont know if the v2 axles fixed the slop in the mount
02-09-2022, 05:47 AM | #12 |
Gen 8 V2 Scout mods - Similar Threads | ||||
Redcat gen 8 scout & gen 7 sport ( epic snow trail adventure ) | shenlonco | Scale Videos! | 0 | 02-08-2019 12:35 PM |
REDCAT GEN 8 SCOUT 2 | MODS & UPGRADES tips & tricks ANYONE CAN DO! | shenlonco | Redcat Crawlers | 2 | 01-21-2019 04:52 PM |
Redcat GEN 8 SCOUT | shenlonco | Scale Videos! | 0 | 01-11-2019 06:42 PM |
