02-26-2017, 10:36 PM | #1 |
Newbie Join Date: Feb 2017 Location: nw
| What Went Wrong? 2 brand new E10s with identical steering/servo problems
Hi folks, just got the E10, my first RC car in... 18 years? Don't know anything about RC cars really, just starting to read the forum and learn. Anyways, got one on Amazon, drove it for maybe 2 hours in the living room and they the steering stopped working reliably, just stopped responding 50% of the time. I decided that was unacceptable and I shouldn't have to repair a brand new item, so I ordered a replacement on Amazon. Hence why I have two at the moment. So the new car arrived and I drove it outside on maybe 3 occasions, built a rock crawling course and after what was maybe some hard driving the last day (but not abusive) the steering stopped working all together. However this one just seems to just want to turn right all the time! It doesn't respond to any adjustment to steering trim or dual rate, turning the car/transmitter on and off doesn't fix it, nor did unplugging/re-plugging the servo, and the whole time you can hear the servo TRYING to turn to the right at all times. You can manually turn the wheels to left/center, turn the car on, it does that little shimmy, and then as soon as you turn the transmitter on, it goes all the way right and keeps trying to turn right, as if it is receiving a signal to do that. You can hear it struggling. (throttle control works fine) So because I had the "older" car (still need to mail it back) I thought I should try that servo on the new car. Without removing it from the car, I plugged the servo into the new car to see if I could reliably control that servo. Nope, it just wants to turn right and keep on turning! Ok, so maybe it's the receiver/transmitter on the new one? I reconnect everything to it's original car, and now BOTH cars are just trying to turn right all the time! The new car does it when you turn the car and then controller on, the 'old' car does it as soon as you turn the car on, without the transmitter being on at all! What in the world is going on? How are both cars doing the same thing? How did one car 'curse' the other with the same problem after testing that servo? |
02-26-2017, 11:51 PM | #2 |
| Re: What Went Wrong? 2 brand new E10s with identical steering/servo problems
Always have the radio on. Always.
02-27-2017, 12:41 AM | #3 |
As in turn the radio on before turning on the car, or literally always keep the radio on? (that would seem strange to me but I'm here to learn) Any ideas what steps I can try in order to fix this? |
02-27-2017, 08:45 AM | #4 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
The e10 servo isn't the best, it's cheap and been know to crap out in non abusive use. The stock servo is hit or miss on reliability. My son's is still kicking after almost a year and have read others crap out quick. The best suggestion is to upgrade it now and that should be it. Remember to adjust the servo before you use it.
02-27-2017, 05:22 PM | #5 |
RCC Addict Join Date: May 2011 Location: at home
might try one of the front servos in the back of the other to see if there is any changes and yes radio on first then plug in battery to esc and turn off radio after unplugging battery from car. ( to save on radio battery life) |
10-15-2017, 05:08 PM | #6 |
Newbie Join Date: Feb 2017 Location: Canada
The E10 I bought my daughter last Christmas just did the same. What's a good replacement servo?
10-16-2017, 01:34 AM | #7 |
Newbie Join Date: Jul 2017 Location: saudi arabia riyadh
| Re: What Went Wrong? 2 brand new E10s with identical steering/servo problems |
10-16-2017, 07:04 AM | #8 |
Quarry Creeper Join Date: Jan 2016 Location: Wichita
Here's a waterproof servo. I use these with great success. The only thing I suggest is buying a metal servo arm which I would do anyway with any servo. https://www.amazon.com/Power-HD-LW-2...WX331GNT68BNG3 Sent from my SAMSUNG-SM-G900A using Tapatalk |
10-17-2017, 08:36 AM | #9 |
Pebble Pounder Join Date: Aug 2014 Location: King George, VA
The E10 is a solid truck. The Hexfly servos are terrible. The big Everest thread here will give you a ton of tips to make the truck better, and all of which are free. Since this thread is older, I'm sure you have seen all of the good content. |
10-18-2017, 06:32 AM | #10 |
Quarry Creeper Join Date: Aug 2017 Location: KY
The servo on mine and my youngest son's E10 went out in the same week. I replaced them with the non-water proof version of the Power HD linked above. Been solid so far. |
What Went Wrong? 2 brand new E10s with identical steering/servo problems - Similar Threads | ||||
problems with steering- on 3rd (all new) servo | petty_xl | Axial Yeti XL | 5 | 09-22-2015 01:29 PM |
steering servo problems... | BM0243 | Axial SCX-10 | 12 | 11-28-2013 07:06 PM |
Help with my HBX Rockfighter,servo steering wrong way | replay | Electronics | 0 | 01-22-2013 12:15 AM |
Steering servo problems | Duramarks | Losi Mini-Rock Crawler | 12 | 12-29-2009 12:41 AM |
Steering servo problems | Ziggy Crawler | Axial AX-10 Scorpion | 7 | 10-13-2008 08:37 PM |
