Thread: steering servo problems...
Old 11-27-2013, 10:17 PM   #1
Default steering servo problems...
I've recently had a lot of problems with my steering in my scx10. I have went through 3 servos very quickly... maybe a battery pack each time. I had a hitec HS-5645MG, a Hitec HS-5646WP and a traxxas 2075 servo. each time i spun the gears inside the servos the hitec servos both have metal gears. i have had axial 2.2 wheels and axial wheel weights for quite some time. I recently put RC4WD wheel wideners all the way around, Vanquish steering knuckles, and Vanquish 8 degree chubs, there is no binding or anything in the steering links nothing hits anything. I'm starting to get a little frustrated (and so is my bank account) and am clueless as to why this is happening... any help would be awesome!
BM0243 is offline   Reply With Quote
Old 11-27-2013, 11:08 PM   #2
Default Re: steering servo problems...
that explains it
that's the straw, 'dat broke 'da camel's b...
you prolly need some unobtanium axles.
and axle bearings mfgr'd at zero gravity.
those might hold up !? Lol
TacoCrawler is offline   Reply With Quote
Old 11-28-2013, 07:14 AM   #3
Why would getting different axles fix my problem with my steering servo?
Old 11-28-2013, 07:48 AM   #4
You'll find most cheap even metal geared servo's still have a plastic gear inside them which is stripping. Due to the extra strain of more steering angle, bigger tyres and more weight the cheaper servo's will crap out. Save your money and buy a high torque servo that can take the strain
English Steve is offline   Reply With Quote
Old 11-28-2013, 07:51 AM   #5
I did buy hi torque servos... Two of them... And also it's the metal gears stripping not the plastic one.
Old 11-28-2013, 07:57 AM   #6
Stick a photo up so we can see how you have your steering. I wouldn't call any of the servo's you bought hi torque. My wrangler G6 runs a HS-7955-TG on 1.9's
Old 11-28-2013, 07:59 AM   #7
Ok when I get off work I'll throw up a picture!
Old 11-28-2013, 08:02 AM   #8
You need something with 250+ oz/in torque at least with those big wheels!
mr lee is offline   Reply With Quote
Old 11-28-2013, 10:48 AM   #9
i run savox 1231sg on my scx and the wifes ax10 with rockbeast 1 477oz at 6v for seventy bucks and my trucks take a hell of a beating they r 80 from rpp
mark32 is offline   Reply With Quote
Old 11-28-2013, 06:19 PM   #10
ok so i took a picture of my steering set up.. after reading a bunch more i realize i need to get better servos. what I dont get is even if i am running servos with not enough torque wouldnt that just not turn my tires as apposed to stripping gears in the servo? to me if its stripping metal gears its still got enough torque...
Old 11-28-2013, 06:36 PM   #11
if youre using the high steer typee knuckles this is a common problem as youre steering is turning at such a radius it strains your servo
The servo isn't the only thing you may find you have a problem with..axles tend to break also with that type set up unless you buy very very expensive axles and servos.
The only thing I can suggest is if you want to keep that set up then use your radio adjustment and reset you end points so it doesn't put the strain on the servo near as much.
Yes you will lose some steering but decide what you feel is more important to you...Buying servos or losing some steering.
6sharky9 is offline   Reply With Quote
Old 11-28-2013, 06:46 PM   #12
If you shorten the throw of the servo and get yourself a longer servo arm. That's what worked for me.
Super is offline   Reply With Quote
Old 11-28-2013, 07:06 PM   #13
Alright thanks for all the help guys. appreciate it!
going to get a higher torque servo and make sure I set the steering end points... honestly didn't know I had to set the end points
steering servo problems... - Similar Threads
few problems with chassis mounted servo and steering m1009cucv Axial SCX-10 16 09-20-2012 06:38 AM
steering servo problems on MRC The Wall Electronics 2 04-29-2010 12:03 PM
Steering servo problems Duramarks Losi Mini-Rock Crawler 12 12-29-2009 12:41 AM
Steering servo problems Ziggy Crawler Axial AX-10 Scorpion 7 10-13-2008 08:37 PM
Steering problems Sean General Crawlers 8 10-18-2005 03:38 PM
