Go Back   RCCrawler Forums > Vendors > RPP Hobby
Thread: New HR aluminum beadlock wheels
Old 01-03-2008, 07:36 PM   #1
RPP Hobby's Avatar
Default New HR aluminum beadlock wheels
Just got in a few sets of these from Hot Racing to see how they look. I have to say they are pretty nice and a great price too. Also the white lettering on the rings is not engraved on its just painted on. So I am pretty sure it can be removed as I have seen some others have done that. These are for 2.2
Price 88.00 for 4
Click here to order ---->
RPP Hobby is offline   Reply With Quote
Old 01-03-2008, 08:13 PM   #2
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Hmmm, I think those outer rings they provide are a bit plain. They need some spiffy-ing up.............oh Pyro
That is a pretty good price for a set of aluminum locks.
Offroader5 is offline   Reply With Quote
Old 01-03-2008, 08:17 PM   #3
RPP Hobby's Avatar
Ill second that
Old 01-03-2008, 10:41 PM   #4
very nice now i must rob the wifes piggy bank
crawldog is offline   Reply With Quote
Old 01-04-2008, 09:11 AM   #5
~THE SCALE SHOP~
ummmm what size?
STANG KILLA SS is offline   Reply With Quote
Old 01-04-2008, 11:54 AM   #6
Originally Posted by STANG KILLA SS View Post
ummmm what size?
The ring on the ground (bottom left) says 2.2 on it. Maybe that's the size?
Any other pics of these available anywhere?
TunaMaxx is offline   Reply With Quote
Old 01-04-2008, 11:54 AM   #7
RPP Hobby's Avatar
Yes they are 2.2
Old 01-06-2008, 06:24 PM   #8
ummmm what size?
Yeah what size : width please !
Can you also tell us what is the hex offset ?
Thanks
Filibuster is offline   Reply With Quote
Old 01-06-2008, 06:31 PM   #9
RPP Hobby's Avatar
Thanks
I try and check tomorrow. Thanks Corey
Old 01-06-2008, 07:08 PM   #10
Is there a hub cap that use the 5 holes in the middle ?
At least, it would be nice to get some hex screws to fill those holes... not a hub cap fan...
I'm interrested in a set.
Old 01-06-2008, 07:13 PM   #11
RPP Hobby's Avatar
They had these as a seperate part, I did not think too many people would like these
Old 01-06-2008, 10:44 PM   #12
I just put a pair on my AX-10 and they are pretty nice. the off-set is flush with the wheel hex so on the AX-10 you gain about 1/2 an inch of track width. I did find that you need to be careful when tightening down the inner rings so they don't bend or use the axial rings which are harder.
Well worth the money!
bmuzz1 is offline   Reply With Quote
Old 01-18-2008, 08:22 PM   #13
are the axial rings comatible with these wheels? also, how well does it bite on M2K's???
STEEL_CITY_CRAWLER is offline   Reply With Quote
Old 01-18-2008, 08:30 PM   #14
RPP Hobby's Avatar
I do not think axial rings are the same pattern. I have not heard any negative info on the bead mounting. Have not opened a set and checked for myself.
Old 02-20-2008, 03:15 PM   #15
Will these keep the track width under 12.5 when used on clod axles.
RotaryRush is offline   Reply With Quote
Old 02-20-2008, 03:37 PM   #16
RPP Hobby's Avatar
Sorry I can not answer that for you, I do not have any on hand to check measurements.
Old 02-20-2008, 08:23 PM   #17
The outer rings will not work because of the 10 hole pattern, but the inner rings are the same pattern as the Axial rings they just need to be drilled out a bit so that the larger HR hardware can be installed. the Axial rings are much more ridged than the HR inner rings and will not bend or warp when installing.
You may edit your posts
