Go Back   RCCrawler Forums > Vendors > RPP Hobby
Thread: NEW! Waterproof Trail Torch!
Old 01-24-2013, 08:54 PM   #1
RPP Hobby's Avatar
Default NEW! Waterproof Trail Torch!
Gear Head RC 1/10 Scale Trail Torch LED Light Bar - Waterproof
FREE Trail Torch Mounting Tab Template
13 Ultra Bright white LEDs in a Low Profile CNC Machined Delrin housing
NOW Waterproof! Ligh bar can run completely submerged!
Approx. 4.25" long.
Includes mounting ears for M2 screws.
Easily connects to an available AUX port on your receiver or an external 3 or 4 battery holder (AAA or AA).
Designed to run on 5.0 to 6.0 volts
Cannot be connected straight to a Lipo or Nimh pack. If coming from the vehicle pack, please use a BEC to regulate voltage to 5V. Connecting to an improper power source will void the warranty.
These LEDs are rated at 12,000 mcd each x 13 = a ridiculous 156,000 mcd
MADE IN THE U.S.A.
Link To Download Detailed Instructions
RPP Hobby is offline   Reply With Quote
Old 01-25-2013, 03:35 PM   #2
Default Re: NEW! Waterproof Trail Torch!
What did you guys do to make it water proof? Just curious cause I have a non water proof version and it would be sweet if it could be waterproof.
Honchoforever1 is offline   Reply With Quote
Old 01-25-2013, 03:39 PM   #3
I joined the Band!
Wondering the same.
Thanks!
Bajacaat is offline   Reply With Quote
Old 01-25-2013, 03:45 PM   #4
Sweet! I'll be ordering one of these!
JHTreyIII is offline   Reply With Quote
Old 01-29-2013, 11:56 PM   #5
Moderator
badhoopty's Avatar
ditto. would like to know the same. i have 2 and i always thought leds were waterproof to begin with.
badhoopty is offline   Reply With Quote
Old 01-30-2013, 11:53 AM   #6
We encapsulate the PCB in a black epoxy potting compound.
You are right, an LED's die and lens are waterproof, but its leads (legs) are not. The other components on our board are also waterproof on their own, but susceptible to corrosion. By potting the entire PCB and the leads of the LEDs, this waterproof version will last much longer if your truck is constantly getting wet and/or muddy.
-Jim
Rpp Hobby/Gear Head RC
Gear Head RC is offline   Reply With Quote
Old 02-01-2013, 09:40 AM   #7
Moderator
badhoopty's Avatar
-Jim
thx for the info.
NEW! Waterproof Trail Torch! - Similar Threads
Gear Head RC Trail Torch LED Lightbar Gear Head RC Scale parts 85 02-10-2013 06:26 PM
Trail Torch Land Crab Scale Accessories 16 03-12-2012 11:36 PM
Gear Head Trail Torch LED Lightbar install ? mrmagoo Axial Wraith 3 02-05-2012 05:02 PM
LD Racing 1/10 Scale Trail Torch LED Lightbar IN STOCK RPP Hobby RPP Hobby 6 09-08-2011 07:48 PM
You may edit your posts
