01-12-2010, 05:28 PM | #1 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| a lil cb.
heres a lil cb i whipped up out of styrene,servo wire. installed it in my AXIAL TR. used several small styrene pieces glued on top of each other for the hand unit. took it to the belt sander and shaped it. drilled a small hole in the bottom of the hand unit for the servo wire. glue together. the radio i cut small squares for top and bottom pieces. 3/4 x 3/4 cut small strips for the sides @3-4mm tall. cut to length and width of box. glue together to form a box. i took the radio part and sanded the edges. drilled small hole for servo wire in back corner for "cb cord". glue. let dry. painted it flat black. detailed it with fine tip brushes and paints. find a place to mount it! i used a small screw and oring to mount. via tiny hole in top of radio. thanks for looking. |
01-12-2010, 05:42 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: Colorado Springs
Awesome! I want one |
01-12-2010, 08:45 PM | #3 |
Rock Crawler Join Date: Feb 2007 Location: weather sucks ,mn
me too
01-14-2010, 04:12 PM | #4 |
Newbie Join Date: Aug 2009 Location: nowhere
how'd you get the wire to stay coiled up like that?
01-14-2010, 04:16 PM | #5 |
Quarry Creeper Join Date: Mar 2008 Location: i think its called houston
looks great mind if i "borrow" your idea |
01-14-2010, 07:33 PM | #6 |
| It's wire.....if you coil it up, it will usually hold it's shape. Already did.....thanks Josh I used a hair thingy to make a bungee for the mic. Last edited by constantmotion; 01-14-2010 at 07:37 PM. |
01-15-2010, 08:14 AM | #7 |
thanks guys! information is free, copy away! looks good greg! |
