Go Back   RCCrawler Forums > Scale Rigs General Tech > Scale Accessories
Thread: 3Racing Winch!! help!
Old 07-09-2010, 08:01 PM   #1
Default 3Racing Winch!! help!
so i was testing my winch for the firt time. i pluged the winch controler into a battery that i use in one of my crawlers....and then i see the wire. IT WAS RED HOT! and caught on fire! what would trigger that?
custom_crawler is offline   Reply With Quote
Old 07-09-2010, 08:41 PM   #2
On the lookout for Rocks
constantmotion's Avatar
What kind of battery? How many volts?
constantmotion is offline   Reply With Quote
Old 07-09-2010, 08:55 PM   #3
1500 NiMH...i used it befor and it didnt do that
Old 07-12-2010, 10:50 PM   #4
same thing just happended to me, i think maybe the wires were touching
corychapman is offline   Reply With Quote
Old 07-12-2010, 11:12 PM   #5
thats a dead short
rmdesignworks is offline   Reply With Quote
Old 07-15-2010, 06:59 AM   #6
The controllers that come with the 3racing winches are half the time no good,I toss it and make my own controller out of a standard servo and plug directly into the spare channel on my receiver.I dont need any extra battery pack,wire harnesses and operate from my radio tq3 with a modded switch.
kuatto is offline   Reply With Quote
Old 07-16-2010, 06:58 PM   #7
I had two controllers burn out in a row on my bench, both were brand new. I'm using an old esc for my winch now with no problems.
YJesse is offline   Reply With Quote
Old 07-18-2010, 12:36 PM   #8
Well from my experience with them if you hook them up to 3s they are toast! the controller can only handle 7.4V. I cooked one and the other two that I have I have hooked to a BEC since I run 3S. Lipos, I do realize that isn't the problem for all some of the controllers are just junk but ...
WarTrader is offline   Reply With Quote
Old 07-24-2010, 05:41 PM   #9
guys there is a easier way just use the stock control but when you hook it don't hook up the black wire to the batt its already grounded on the receiver. this only works if your running all on the same batt
turtle77 is offline   Reply With Quote
