12-19-2010, 03:45 PM | #1 |
Newbie Join Date: Sep 2010 Location: Aus
| 3Racing scale winch
Does anybody know if it will damage the winch powering it directly from a 9vt battery, instead of running it through the car battery, in my case, 7.4 volts? Just seems easier to hook it up via a 9vt battery than splicing it into the main electrics.... thanks |
12-19-2010, 03:59 PM | #2 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
The winch itself will handle it no issues its the included control unit that may kick the bucket. You can give it a try but it cant be guaranteed that the control unit will survive.
12-19-2010, 07:58 PM | #3 |
Rock Stacker Join Date: Dec 2009 Location: Kilgore
Mine runs on 3s.
12-20-2010, 07:10 AM | #4 |
12-20-2010, 08:48 AM | #5 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
read the instructions..7.4v max input. you can run it higher voltage but run the risk of shortening the life span of the motor. |
12-20-2010, 10:58 PM | #6 |
Pebble Pounder Join Date: Apr 2009 Location: lake saint louis
I would throw out that junk control board if you dont need it. I have replaced all of my control boards. I run old servos on my third channel to power and run the winch works so much better. Gave me variable speed as a bonus. |
12-21-2010, 02:24 AM | #7 | |
Thats not entirely true, i've run my 3r winch on 3s for over a year and never had an issue with the motor, i burnt out the stock control board but the motor is fine. Theres a guy over here as well that has run one on 4s and hasnt had an issue with the motor, he's shattered a couple of the stock gearboxes but again his motor is fine. | |
12-21-2010, 10:38 AM | #8 | |
Are you running it directly off of the 3S or 4S battery or is that the battery that is powering the whole truck? | |
12-21-2010, 01:16 PM | #9 | |
The esc's are only rated at 6cells Nimh/2s lipo. But the 3r winch doesnt pull enough amps to worry the esc even at stall. I have run one off a separate plug in controller made from a 3pos 6 pin switch & 3s 640mah battery didnt worry the winch motor but fried the little 3pos switch i was using after 4-5pulls. Last edited by WIDELOAD; 12-21-2010 at 01:20 PM. | |
12-24-2010, 08:08 AM | #10 | |
hmmm... well i may have to give it a try as well then.. isnt there someone who sells boards for these?? | |
12-25-2010, 10:29 PM | #11 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
I run mine off of a Mamba 25 just for the winch off of a 3s. Works like a charm every time |
12-29-2010, 07:34 AM | #12 |
Rock Crawler Join Date: Feb 2004 Location: Michigan
Running mine for a year on 3s tapped from the esc, no problems yet but the controller will get "warm" during extended use.
12-29-2010, 09:33 PM | #13 |
Pebble Pounder Join Date: Mar 2010 Location: Back in the sticks
Dont do it! I tried and it worked for about 30 seconds. Then the board started smoking and little flames came shooting out. And im out $15!
12-29-2010, 10:36 PM | #14 |
Rock Crawler Join Date: Jun 2007 Location: Nova Scotia,Canada
I build the controllers from servo boards,plug directly into a spare channel and work great
01-01-2011, 06:44 PM | #15 |
Newbie Join Date: Jan 2010 Location: At Work
I have been running mine from a 9volt battery. I have a dx3 with a 3pos switch that i wired into it. The winch plugs into the 3rd channel on my receiver. So far it has worked great for almost a year.
