01-28-2011, 04:49 PM | #1 |
Pebble Pounder Join Date: Aug 2010 Location: claremont... for now
| winch help
so i just bought the Bulldog 9300XT from rc4wd i also just started using 3 cell so i put a bec in, as u must all kno 3 cell and winches dont mix lol so my ?? is, is there any winch that will work with a bec and 3 cell or am i shit outa luck thanks for ur help guys! |
01-28-2011, 05:06 PM | #2 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
I believe you are out of luck unless you make a servo winch.
01-28-2011, 05:30 PM | #3 |
Rock Crawler Join Date: Feb 2010 Location: costa rica
I really don't see the problem if you have a bec than connect the winch to the bec and limit the output to 6 volts. I don't see a problem in that at all...
01-29-2011, 10:04 AM | #4 | |
i was also thinking of just buying the wireless and hooking up an external power supply | |
01-29-2011, 10:19 AM | #5 |
Well black and red have to be connected to the bec and the signal cable (brown or white) has to go to the receiver.
01-29-2011, 10:56 AM | #6 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
Cut the servo J style connector off of the BEC, about 1-2" back from the plug end. Strip the black and red wires. Solder a Deans 2R micro plug onto the BEC wires, so that the male side of the plug is negative(black), positive is the female side. The solder the second Deans in the pack, on the input wires of the winch controller, but in reverse order, black is the female side, red on the male side. CC BEC puts out 5A continuous. What does an RC4WD winch pull when almost at stall?? Deans 2R http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDKA2 There are other BEC type regulators out there that might handle more or you could go with the larger BEC that CC makes. Dimension Engineering makes some regulators for robots. Not sure what is out there. Try the CC BEC. Worst case your into a $6 repair fee if it frys. |
01-29-2011, 10:58 AM | #7 |
Chances are the winch has one of these (micro not mini sized) motors in it, which looks like the bigger ones draw 1.6A at stall. So you should be fine. http://www.pololu.com/catalog/category/51 |
01-31-2011, 05:32 PM | #8 | |
when i ran my bec i soldered the red and black to the esc and then the bec plugs in to the remote servo so where am i running the red and black winch wire to? to the solder point on my esc or thanks for the help boys | |
01-31-2011, 07:30 PM | #9 |
01-31-2011, 07:36 PM | #10 |
Maybe this will help. eric113's honcho flatbed now with portals |
02-07-2011, 10:08 AM | #11 |
Newbie Join Date: Nov 2010 Location: lincolnton
if u get stuck ur a faggggg hahahaha jk dennis |
02-07-2011, 10:28 AM | #12 |
Rock Crawler Join Date: Sep 2007 Location: Petaluma
i was using the 10th scale 3r winch on 3 cell with no problems,but now im using the 8th scale 3r winch on my 10th scale scaler..
02-08-2011, 06:16 PM | #13 | |
yea the more i searched the more i saw alot of ppl use this setup and dont have problems, i think it matters on bec and how u install it my winch just keeps spinning and spinning, nd then will studder for a bit | |
