05-04-2011, 11:37 PM | #1 |
Rock Stacker Join Date: Jan 2007 Location: Philippines
| Ammo crates/ toolbox / battery case
Hi guys, just though of sharing my AMMO CRATE/Battery Box Before the build just a little background on how I came up with the idea. I was actually searching for a picture of a Flat Bed Yota and end up following this bed I also need to put toolbox but I have to extend it down to the floor to fit my battery and hide the adj clutch of the SCX10 Tranny as well but then it may look like a coffin too me. Then I came across this picture and gave me an idea of using AMMO Crates for toolbox, further search proves that ammo crated were indeed used in off roading as toolbox And the idea took off using this crate as my reference used Balsa wood 1/8" thick. I use blade instead of a saw in cutting the plywood. It leaves smoother edge In just less than an hour of cutting and gluing Test fit my 3S 2500Mah Lipo batt I use 0.40mm thick brass plate and 1/16 brass rod for the hinge. Unfortunately 2mm is the smallest screw I have so it didnt look scale on the hinges. I change the locking mechanism to a conventional one so I can use body clip to lock it. With the basic gray paint (notice the added pins that work as nails) I used letter Transfer decals for label details Scuff the paint and edges for some wear and tear Added some rusting effect on nails now on the mounting to bed I preffer to use Velcro so I can transfer the Crate/batt box to my other rigs when needed. here it is finished thanks for looking |
05-04-2011, 11:55 PM | #2 |
Quarry Creeper Join Date: Apr 2009 Location: Wyoming
Very nice i like that alot
05-05-2011, 02:11 AM | #3 |
Newbie Join Date: Oct 2009 Location: SLC
that is awesome! i will have to steal that idea |
05-05-2011, 04:41 AM | #4 |
Thanks be my guest |
05-05-2011, 08:21 AM | #5 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Great job!!!!
05-05-2011, 09:08 AM | #6 |
Very well done. would like to get one or make one for my Jeep. |
05-05-2011, 09:17 AM | #7 |
nice job, great reference pics. If you want smaller hardware, check out 00-90 hardware, it's smaller than the 2mm stuff.
05-05-2011, 10:26 AM | #8 |
Rock Crawler Join Date: Jul 2008 Location: E. City
Nicely done! It like great and is functional! |
05-05-2011, 10:41 AM | #9 |
RCC Addict Join Date: Oct 2007 Location: gervais
Have you thought of waterproofing the inside or outside for water use?
05-05-2011, 03:23 PM | #10 |
Newbie Join Date: Apr 2011 Location: Rabble
That is probably the most functional scale item I have seen so far. Very nice job with the patina!
05-05-2011, 04:47 PM | #11 |
Pebble Pounder Join Date: May 2005 Location: so. cal
brilliant idea! Looks great.. do you think you'll try the rope handles?
05-05-2011, 08:49 PM | #12 | |||
And thanks for giving us an idea, this is also good in hiding electronics. Quote:
Thanks again for the rest, its makes the sharing worth it | |||
05-05-2011, 09:26 PM | #13 |
Rock Crawler Join Date: Feb 2010 Location: in a Fishbowl watching time go by
very cool ...great work
05-06-2011, 11:32 AM | #14 |
Rock Stacker Join Date: Dec 2010 Location: tallahassee
Very nice, looks like I'll be getting some wood after work
05-08-2011, 04:25 AM | #15 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
How did you roll the brass? I tried today to roll some around the 1/16 rod and man did it look messed up.
05-08-2011, 10:00 AM | #16 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
very nice job! |
05-08-2011, 06:51 PM | #17 |
05-08-2011, 06:56 PM | #18 |
05-13-2011, 11:33 PM | #19 |
Rock Crawler Join Date: Jan 2011 Location: singapore
Very nice! I love that ammo box!
05-14-2011, 01:41 AM | #20 |
Newbie Join Date: Apr 2011 Location: Virginia Beach
nicely done, looks great.
