08-11-2012, 11:38 AM | #1 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
| Build your own Pull Pal
**These are NOT for sale or trade - just make your own..it's easy!!** You need a cotter pin bent as shown and a flat piece of metal (PC expansion slot covers work great!). Drill a hold in the end of the cotter pin for a tow shackle. Solder the metal to the cotter pin Trim the corners Grind it smooth (depending on your soldering skills!) Grind a flat spot for the shackle Paint it an add some heat shrink tubing for handles/grips Add a cotter pin tow shackle and you're done! Stone Cold says "Go Prepared! Last edited by BubbaEinstein; 08-11-2012 at 05:05 PM. |
08-13-2012, 01:32 AM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: Build your own Pull Pal
Looks good. Are these more for show? Cotter pins are soft and can be bent by hand.
08-13-2012, 05:15 AM | #3 |
These are steel and fully functional...i can hang my rig on it no problem.
08-22-2012, 10:44 AM | #4 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
Cool!
02-13-2013, 01:50 PM | #5 |
Pebble Pounder Join Date: Aug 2012 Location: Englewood, CO
Nice stuff, I've checked out all your accessories and even made the cotter pin shackles myself, but I have a few questions. 1) What size cotter pins did you use? I used some rather large pins because even the smallest drill bit takes the hole right to the edge of the pin...what did you use to drill out the holes? It looks like your pins are smaller than mine, and I'd like to make smaller ones. 2) When you soldered the plate on to the pin, you just used a regular soldering iron and solder? No brazing? Thanks in advance :-) |
02-13-2013, 08:42 PM | #6 |
I have my stuff packed right now during winter (our garage turns into a greenhouse...and the garage is where I work on RC ) but I think I got the 2nd biggest size tractor supply had...basically just bought by look. As far as drilling the holes, I went to harbor freight and bought a big pack of tiny drill bits (sorry don't remember the size but they were tiny). I used a dremel to start the hold and then drilled them out...keep the bit greased up...and fyi I usually got 2 or 3 hooks drilled before the bit broke. Yep, when I soldered I just used the soldering iron (no brazing). Good luck!! |
02-13-2013, 11:26 PM | #7 |
Pebble Pounder Join Date: Dec 2010 Location: Fresno
Awesome, thanks for the how-to on this! (sorry for crappy pic) Just need some paint and I'm good to go. |
02-15-2013, 10:41 AM | #8 |
Quarry Creeper Join Date: Nov 2007 Location: Funky Town
I can dig it.... Very cool and simple! |
02-15-2013, 12:06 PM | #9 |
| Re: Build your own Pull Pal |
02-16-2013, 11:22 AM | #10 |
02-16-2013, 12:28 PM | #11 |
05-16-2013, 04:58 PM | #12 |
Newbie Join Date: Apr 2012 Location: Mclean
Well done. Does it really hold up to abuse on on the trails though. Making this when I get home |
05-16-2013, 08:12 PM | #13 |
Yep...Rock Solid |
05-17-2013, 04:19 AM | #14 |
Newbie Join Date: Feb 2013 Location: Upper Michigan
High temp engine paint works good if you cure it in the oven as per directions
05-20-2013, 11:38 PM | #15 |
Rock Stacker Join Date: Feb 2011 Location: flathead
Yea this is sick I built one out of a nail an some steel not sure the gage of it but welded it up an painted it red looks decent
04-28-2014, 09:44 AM | #16 |
What could go wrong? Join Date: Oct 2013 Location: Southern Ontario
Pretty big thread bump, but thanks for this! I need a pull pal for a upcoming comp, but have completely exhausted by budget atm, so the will be perfect. I'll have this a go tonight and post pics of how it turns out. |
04-28-2014, 09:51 PM | #17 |
Build your own Pull Pal - Similar Threads | ||||
my pull pal.......... | bob1961 | Scale Accessories | 5 | 03-14-2012 01:12 PM |
Pull-pal anchor | zumzum5150 | Scale Accessories | 128 | 10-07-2010 05:51 PM |
Pull Pal | RoadKing | Scale Accessories | 6 | 05-17-2008 06:52 PM |
