Go Back   RCCrawler Forums > Scale Rigs General Tech > Scale Accessories
Thread: Scratch Built garage accessories
Old 08-11-2016, 10:31 AM   #1
Default Scratch Built garage accessories
Built this floor jack out of styrene using the 1:1 for reference. It does articulate but won't hold any weight. I used a soldering iron that accepted a #11 exacto blade, and used the side of the hot blade to mushroom the styrene pins allowing movement while holding it together. The jack stands are also made of styrene.
Bucko is offline   Reply With Quote
Old 08-11-2016, 03:40 PM   #2
Default Re: Scratch Built garage accessories
That is some very good detail work on the jack and stands.
rerebuilder is offline   Reply With Quote
Old 08-12-2016, 04:43 PM   #3
Thank you for the comments.
Although not totally scratch built, I had to try cutting with thread (it works) and sacrificed a Mojave cab. I cut the cab along the body lines, then using styrene built the inner structures. Now they can collect scale dust in a scale garage.
Old 08-12-2016, 04:55 PM   #4
That jack is impressive, do the stands hold much weight?
ADlBOO is offline   Reply With Quote
Old 08-12-2016, 05:11 PM   #5
They aren't as strong as the steel ones, but they are holding a stock SCX10 in the photo. Thank you for your compliment.
Old 08-12-2016, 06:16 PM   #6
You, Sir, are a highly skilled craftsman. The detail of these, like your V8, is Top-Notch !!
Thanks for sharing.
dr frankenstyle is offline   Reply With Quote
Old 08-12-2016, 08:55 PM   #7
Thanks for sharing.
Thank you very much, it's my pleasure.
Old 08-13-2016, 06:46 PM   #8
Made a couple of brake drums from water bottle caps and a little styrene, sprayed them with red oxide primer then weathered.
Old 08-13-2016, 07:30 PM   #9
What a great idea^
Mike Flea is offline   Reply With Quote
Old 08-14-2016, 04:17 AM   #10
WSD
Super clean work and highly detailed. Fantastic work my friend. If you font mind me asking what stock did you use to make the jack?
WSD is offline   Reply With Quote
Old 08-14-2016, 08:53 PM   #11
Thank you for the compliments. The jack is made from Evergreen styrene, the side panels are cut from .040" sheet and the other parts are made from the many different shapes they offer. I'm fortunate to have a well stocked LHS nearby.
Old 08-18-2016, 07:38 PM   #12
Here's a couple more styrene items. Couldn't find anything that looked right for the chain on the chainsaw until I found this ball chain at the LHWS.
Old 08-19-2016, 06:08 AM   #13
wow your work is amazing! love the detail that you go into creating these! the wood grain in the logs and teeth on the chain saw are awesome. You are very skilled my friend.
Cali_Lightning is offline   Reply With Quote
Old 08-19-2016, 06:59 AM   #14
Absolutely some of the best scale garage accessories I have seen. Your fab skills are next level. That chain saw is amazing!
joe122 is offline   Reply With Quote
Old 08-19-2016, 09:34 PM   #15
Thank you guys for the compliments. I have gotten a lot of ideas and inspiration from lurking this site, so many creative and talented contributors. My wife urged me to finally join and share. Thanks for your interest.
(The log pile is real wood, it shouldn't have been in the photo.)
Old 08-20-2016, 08:09 PM   #16
Very nice work! So cool that there is functionality to the items.
pardonmyn00b is offline   Reply With Quote
Old 08-22-2016, 07:15 PM   #17
Picked up some basswood strips of various sizes from the LHS, then used this cutter I made from a scrap steel plate, angle iron, key stock, some aluminum strips and a single edge razor blade to build this folding ladder. The cutter does a fine job with thinner wood, straight, clean cuts. Used some styrene rod and the same hot knife method used on the the jack for the pivot points and styrene hinges.
Old 08-23-2016, 07:06 AM   #18
That is some very impressive woodworking skills on such a small project. Your work is off the charts.
Old 09-07-2016, 01:33 PM   #19
Here is my scale garage. Nearly all of the items are scratch built. Thanks for checking it out.
Old 09-07-2016, 03:36 PM   #20
You Sir, know how to make an entrance
I for one, would very much like to see a play by play on Everything. No matter though.
Thank you for sharing! And thank the Misses too. We owe her Big Time
2kind is offline   Reply With Quote
Scratch Built garage accessories - Similar Threads
1:10 Scale Garage Accessories Stomper Fan 777 General Scale Talk 0 05-12-2015 10:44 AM
scale garage accessories ReMiXeDg General Crawlers 5 09-15-2014 07:25 PM
Another scratch built JK rottenbelly 1.9 Scale Rigs 36 11-14-2011 05:46 PM
Scratch built rag6 Newbie General 2 06-30-2011 07:50 AM
Scratch built 2.2 Kamikaze Tamiya Clod Buster 26 09-11-2007 07:51 PM
