Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > Scale Accessories
Thread: Shifter boot
Old 04-02-2007, 04:49 AM   #1
Default Shifter boot
Check out a DuraTrax Carburetor Slide Dust Cover G-27CX.
http://www2.towerhobbies.com/cgi-bin...?&I=LXLDJ0&P=Z
It's about a .5" tall and wide. Similar dust covers could be used from other motor mfg's.
BrockGrimes is offline   Reply With Quote
Old 04-02-2007, 07:08 AM   #2
nice idea
chino438 is offline   Reply With Quote
Old 04-02-2007, 01:43 PM   #3
Sweet
For gear shifter boot, i use the rubber that’s on the end off bicycle brake wires. Used it as a rubber boot for some shocks as well. They are a bit stiff, so they can cause the shocks to be a bit slow in action (hope my spellings ok).
Shocks:
Hilux is offline   Reply With Quote
Old 05-31-2007, 04:23 PM   #4
You could also use the shock boot from a Thunder tiger 1/8 buggy or the drive shaft boots made by Sportswerks.
Kermit is offline   Reply With Quote
