11-25-2007, 09:02 AM | #1 |
Rock Stacker Join Date: Oct 2007 Location: dahlonega
| fiber glass leaf springs
has any body tryed makeing or using fiber glass leaf springs because fiber glass is stronger than lexan and if thin enough it is more flexable too.
11-25-2007, 11:04 AM | #2 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
go for it, let us know how it works out for you.
11-27-2007, 03:24 PM | #3 |
Pebble Pounder Join Date: May 2007 Location: South Africa
Sounds like a good idea! I might try it my self if you don't mind.
11-27-2007, 03:52 PM | #4 |
ever seen a wrecked corvette?
11-27-2007, 04:22 PM | #5 |
no never, dont they have composite rear leafs?
11-27-2007, 05:50 PM | #6 |
lol i assume thats sarcasm. the whole damn body is composite. well early days were true fiber glass, now there a hybrid composite as you mentioned. same as my SS, only metal on the entire body is the rear quarters and B-pillar |
11-27-2007, 05:53 PM | #7 |
| yah you would probably be able to do it befor i do cuz i dont even have a crawler yet (hopeing to get a high lift for x-mas) and was wondering if that would work or not. but go right ahead i would like to see how they work |
11-28-2007, 06:59 AM | #8 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
11-28-2007, 08:38 AM | #9 |
yep. Z28s have steel rear quarters, hood, and B pilliars, everything else is composite. SS adds the fiberglass hood, leaving only the rear quarters and b-pilliar as the only steel on the body. correct, C5s and C6s are 100% composite. |
11-28-2007, 09:21 AM | #10 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
They actually make fiberglass leaf lift for 1:1 yjs..Should work fine..
11-28-2007, 03:34 PM | #11 |
11-28-2007, 03:37 PM | #12 |
yeah but the leaf would be so thin, i dont think it would a good solution.
11-28-2007, 04:16 PM | #13 |
has any body tried the rc4wd leafs on the high lift? if so are they any good |
12-01-2007, 08:46 PM | #14 |
Rock Crawler Join Date: Jan 2006 Location: woodpile aka HELL
the fiberglass might be good if you make them right, if they can put them on 1:1 cars, then we should be able to do the same
12-18-2007, 01:08 PM | #15 |
Quarry Creeper Join Date: Mar 2006 Location: PORT ORCHARD WA
I think I would be itchy by the end of the day |
12-18-2007, 01:46 PM | #16 |
I have thought about this quite a bit. I will be using stuff called "woven roven". It is weaved like carbon fibre, but allot stronger. I have built a 1:24 micro pan chassis for Iwaver racing and it is strong like hell! I found if I seal off the edges with CA, it is much stronger and does not delaminate.
12-18-2007, 01:51 PM | #17 |
carbon fiber doesnt bend....... so if "woven roven" is stronger.....how ya gonna get your flex? |
12-22-2007, 02:05 PM | #18 |
12-22-2007, 02:12 PM | #19 |
well what about a bilayer crabon fiber with a flexy epoxy? we could have leafs as thin as the steel ones and that would have springy effect right? we could more fine tune the rate with leaf length and qty. hmmm. can you make the "eyes" in CF?
12-22-2007, 04:23 PM | #20 |
| sure you could make the ''eyes'' by taking cf tubing and cut it to the right length and epoxy it on the to leaf.
