02-21-2012, 01:11 PM | #1 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
| Boatsides
I see I'm allowed a 1" tall boatsides in class 3. Where is that measured from? I get that it's vertical but is it from the point it starts to slope up to the body or from the bottom of the frame? Just trying to decide the best way to build, attach, and stay within rules.
02-21-2012, 02:20 PM | #2 | |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: Boatsides Quote:
02-21-2012, 03:04 PM | #3 |
Oh boy... You just opened up a whole new world for me lol. Thanks! Side not for others looking where is it measured from in class 2? |
02-21-2012, 03:11 PM | #4 |
| Re: Boatsides |
02-21-2012, 04:43 PM | #5 |
Cool. On an Scx the skid hangs below the frame so you can't really go much higher. But I guess every bit counts. Good thing I'm doin a class 3. Bring on the body scissors. Lol
03-02-2012, 09:32 AM | #6 | |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Wow, that sucks for me. I wish it was better defined in the rules section. My C2 Unimog was based upon what I read there. Now I have to redo the entire bed, battery tray, cab mount and boatsides, basically the whole rear of the truck. My boatsides start just above the framerails and are less than 1" to the top edge where it angles up perpendicular to the ground. They also incorporate the bed mounts as well as the rear cab mount and battery tray at the front. Here's the mock up picture so you can see what I have going on. It measures just over 1.5" from the bottom of the skid to where it angles up just under the bed. Last edited by chino63; 03-02-2012 at 10:04 AM. | |
03-02-2012, 10:24 AM | #7 |
| Re: Boatsides
Don't start redoing anything quite yet Dean. This rule wasn't designed to stifle builds, it was made to keep people from chopping the bottom half off of their body off. I'm not even sure it's considered a boatside if it on a flatbed. We'll let you know.....
03-02-2012, 10:57 AM | #8 |
I wanna be Dave Join Date: May 2006 Location: akron
| Re: Boatsides
The rule says measured vertically.. it does not say where the boatside is mounted.. So locally I measure from base of boatside to top of boadside..
03-02-2012, 11:22 AM | #9 | ||
ok, thanks. I will hold out till you let me know. The body is full height and the truck is top heavy with a full drop bed and stands 9.5" tall so... Last edited by chino63; 03-02-2012 at 11:29 AM. | ||
03-02-2012, 11:44 AM | #10 | |
What it should have said was "from the bottom of the boatside (where it attaches to the frame) to where it meets the body should be no more than 1" tall measured vertically." Sorry guys . | |
03-02-2012, 12:51 PM | #11 | |
So is it as Sloppy stated where he measures only the angled section or as in my case, the entire piece of steel from bottom of frame mounting flange to the top edge where the bed rests on top of the upper channel. If it's the whole thing I'm in trouble. if it starts where it angles up then I'm good since that part is less than an inch to the top. Frame mounting flange height: 3/8" Angled section height: 5/8" Top channel height: 1/4" Thanks again. | |
03-02-2012, 02:56 PM | #12 |
| Re: Boatsides
Your truck is fine how it is Dean. Sorry about the confusion.
03-02-2012, 03:24 PM | #13 |
| Re: Boatsides
So you guys know what I'm talking about....a picture is worth a thousand words. |
03-02-2012, 03:55 PM | #14 |
| Re: Boatsides
See I measure this.. just so no one goes crazy on that mount leg to the frame.. Either way Dean is good I guess in this case I am the bigger ruler nazi Last edited by sloppy; 03-02-2012 at 04:04 PM. |
03-02-2012, 09:26 PM | #15 |
| Re: Boatsides
awesome, thank you guys for the clarification.
03-04-2012, 08:55 AM | #16 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
| Re: Boatsides
Maybe word it as: For boatsides, the cab must not measure more than 1" vertically from the top of the frame rails to the bottom edge of the cab.
03-04-2012, 09:30 AM | #17 |
| Re: Boatsides
That is actually pretty good . You want to be part of the committee .
03-04-2012, 09:42 AM | #18 | |
Thank you, I'm usually not too good with words. I'm like a virus, seems when I'm part of something, that something deteriorates(spelling?). Last edited by travis c.; 03-04-2012 at 09:48 AM. | |
08-20-2012, 09:29 PM | #19 |
Newbie Join Date: Feb 2012 Location: London
| Re: Boatsides
So, if the body is actually on the outside of the boat side, nothing removed from it, is it still a boat side? I put floors under the the cabs of my truggies that act as sliders, but they don't replace any of the body. I'm a little ignorant on the subject.
08-20-2012, 10:07 PM | #20 |
| Re: Boatsides No a boatside is removing the body and replacing it with a skid that gives you more clearance.
Boatsides - Similar Threads | ||||
Let's see your boatsides! | SStone | 1.9 Scale Rigs | 5 | 05-22-2012 07:48 AM |
SCX F350 with boatsides | rckjeep | Axial SCX-10 | 78 | 03-28-2012 11:13 AM |
