01-26-2011, 03:48 AM | #1 |
Newbie Join Date: Jan 2009 Location: finland
| vw snow crawl and hearse testing
video from finland, sorry for the quality, my lens was frozen. vw camper van 1:12 body, 1:18 independent suspension axels + torsion bar, helicopter motor and reductor, losi mini sandpads with 40 pins each. new project. based mostly on losi mini lst parts, cutting board and beercans. video from spain. |
01-26-2011, 10:20 AM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
frozen lens I was out driving last weekend,and after a break in the 1:1 dodge ram charger my honcho was frozen and couldent move. 2 minutes over 5 candles and my honcho was literally steaming and running again Its not mutch fun running in sub zero temperatures, but i just had to dirty up my new Dick Cepek wheels up to match the DC tires i allso have. |
01-26-2011, 11:02 AM | #3 |
my camper van works best in -20°C , anything more than 0 it will overheat. so its pretty much a winter car. .. it was still going in -32°C but i had to stop for frozen fingers and toes. there was one problem, glue in diffs got unglued because of the cold. Last edited by sauhu3000; 01-27-2011 at 01:02 AM. Reason: typos |
01-26-2011, 06:45 PM | #4 |
Quarry Creeper Join Date: Jan 2009 Location: Bay City
Love the look of the hearse.
01-28-2011, 04:41 AM | #5 |
Newbie Join Date: Oct 2009 Location: SLC
where can i get that body!? my everyday driver is a 77 V.W. bus
01-28-2011, 12:24 PM | #7 |
thanks!!!!
02-01-2011, 08:59 AM | #8 |
testing new steering and speed with 23/55 gears. turns too much and pump steers, which is causing dogbone problems. im going to do a new spur, something around 80t might be ok with the small 11t pinion. also now i have to start all over with the steering... http://i30.photobucket.com/albums/c3...g?t=1296575843 http://i30.photobucket.com/albums/c3...g?t=1296575864 http://i30.photobucket.com/albums/c3...g?t=1296575869 |
02-05-2011, 02:02 AM | #9 |
| 12/82 gears
new 82T spur from kyosho ultima, pinion is 12T from asso. 82T is the biggest possible, there is now less than 1mm space between the spur and the driveshaft. car is starting to be ok for backyard fun, but needs a bigger motor. there is no low end torque and the car jumps the rocks instead of crawling over. also the rear diff lock is slipping badly, needs more pattex. Last edited by sauhu3000; 02-05-2011 at 02:09 AM. |
