Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Loading
Thread: WK Full Droop Comp Chassis!
Old 05-10-2009, 09:23 PM   #1
Default WK Full Droop Comp Chassis!
Well i got bored of the AX10 RC i have so i've started to aquire some WK parts. Startign with the tranny.
this is a 2" wide full droop comp chassis based on a WK tranny. Right now i have it with AX axles under it but that could change.
I haven't done the control arms yet. but thats next.
this even has a full functioning drive shaft dig. and chassis mounted servo.
my tranny shoudl arrive in a week or so. I will be cutting the chassis hopefully in the next 7 days.
Kraqa is offline   Reply With Quote
Old 05-10-2009, 10:16 PM   #2
i started playing with the shocks extended. fully then flexing it out.
Old 05-10-2009, 10:21 PM   #3
the axles are contrained in the model as if it has control arms. i just didn't feel like modeling them.
Old 05-10-2009, 10:29 PM   #4
Very interested.
calikingcrawler is offline   Reply With Quote
Old 05-10-2009, 11:13 PM   #5
I am all for the WK based rigs but usually one would work off the Axles and use a different Tranny. IMO, You should at least start development on the correct foot and engineer the rig to have a clocked motor plate or some other custom mounted motor. I am building an FJ40 that will have a separate bracket for the motor for lower CG... Interested to see this build come alive.
I will follow this for sure.
JB
CruiserHead is offline   Reply With Quote
Old 05-11-2009, 10:17 AM   #6
If you look closely the motor is mounted extremely low. In fact it is only about ¼” higher then the Axial set-up when measured form the skid plate. The goal of this chassis was to make it narrow and have the weight up front.
I have made clocking rings for the WK that gets the motor resting on the skid plate but the chassis width is 3.5” at the very best. This chassis is 2” wide.
If you look at the Axial comp chassis that are this widt it has 3/4 of the motor hanging out of it to one side. This is a true 2”.
The reason for the WK tranny was for the width. I will be making this with arms and axle mounts to use the WK axles as well for a buddy.
If it works it is a great upgrade for all the guys thinking about switching to a Axial.
Keep following the thread……input is appreciated.
Old 05-11-2009, 10:23 AM   #7
I like how you mounted the motor...of course I'm kinda partial since I did the same thing on my pro comp WK
billet works is offline   Reply With Quote
Old 05-11-2009, 10:55 AM   #8
no surprize.
when its a good idea people will use it!!!
hahaha
Old 05-11-2009, 03:16 PM   #9
I Would like to see the motor mount/bracket by itself of you have any pictures, please. Looks like an integrated mount/frame brace. Since I am going to mount the motor in the engine compartment it might help me to get the 'ol brain thinking on the correct wavelength to fab a bracket.
Also, I have a chance to take a surf cam class this summer. That a good one to take before CNC machine operation or after? I can't decide how far i want to go with my schooling but "All the way" would be the ultimate. I dream about making all my own parts with a CNC rig.
Later!
JB
Old 05-11-2009, 05:04 PM   #10
Your right. The motor mount is mounted to the frame and doubles and a chassis stiffener.
When I get home I’ll show a more in depth picture.
Why I think this will work so well is that I plan on using all the factory tranny mounts. The posts on the side of the tranny are quite long but in my case I have decided that I will be sanding them down to make the OA width of the tranny 1.5”.
But having the tranny mounted in 6 locations should be VERY stiff.
Old 05-11-2009, 05:29 PM   #11
It's been a while since I've seen a 60/40 split TVP chassis. Looks pretty good though! I really like the idea of the motor out front, wish I could have thought of it first I'm interested to see how the set-up works with droop and having the skid plate so small, might just be the ticket!
TOM
sourdojack is offline   Reply With Quote
Old 05-11-2009, 05:44 PM   #12
Whats your paypal
I love this design, keep up the good work
701 Technique is offline   Reply With Quote
Old 05-11-2009, 05:46 PM   #13
you should put this in the wk chassis template thread, looks like a good chassis
grizz is offline   Reply With Quote
Old 05-11-2009, 06:06 PM   #14
ok heres the motor plate. i ave changed the colour to Red so you can see it better.
I'm goign to try it out of Delrin first....if that fails then i will go aluminum.
i ordered up some new cutting bits for the table today. shoudl be here in a week or so...
then i can start playing around with this in real life.
tonight i'm hoping to get the WK axles fully model'd. i'll let you guys know how it turns out.
Old 05-11-2009, 07:51 PM   #15
Hateraide
Code454's Avatar
you should just make the motor plate out of metal to start with than no problems at all, unless how thick you making it?
Code454 is offline   Reply With Quote
Old 05-11-2009, 10:06 PM   #16
k got the WK axle model'd.
now i can get to the real work....makin' this chassis work with a WK axle.
Old 05-11-2009, 10:46 PM   #17
ok well the link mounts, shock mounts, and drive shafts are all in generally the same location. this is good.
i actually liek the factory mounting clips when turned up. We'll see if i end us using them or makign new ones.
Old 05-12-2009, 01:14 AM   #18
Would you mind sharing the Solid Works models? I'm still learing Solid Works and would love to see how you modeled some of these parts.
~petev
vavaroutsos is offline   Reply With Quote
Old 05-12-2009, 10:55 AM   #19
Very excited Kris!! This thing looks kill! And its going too work awesome!
EHeye is offline   Reply With Quote
Old 05-12-2009, 11:42 AM   #20
Hateraide
Code454's Avatar
That aint gonna work Kris jk, did u get any more done lastnight
You may not edit your posts
HTML code is Off
