#1 |
Ummmm....mmmm.m....mm OK.
![]() Join Date: Sep 2007
Here is a build up of my Bully axled comp rig for 09'
I started with a self made custom Delrin chassis. ![]() Drilled and re-tapped a set of TCS bent links to 8-32 so I could use large Traxxas rod ends. ![]() ![]() ![]() Then I got a set of Revo GTR shocks I'm using yellow springs in the front and greens in the rear. ![]() I run a set of Eritex Delrin solids with Proline Chisels and stock foams. I run no wheel wieght. ![]() I then made dig switch using Honeywell V15H22-CZ100A02-K 22 amp switches, and a Hitech HS-55 servo. ![]() Here is the assembled chassis. ![]() I run a JR z9100HVt steering servo. ![]() I ran my first comp and did ok. I was out of practice and placed 7th. ![]() Next comp was much better as I had gotten a lot of wheel time. Placed second. ![]() I run Integy motors 55t front 45t rear 3s 1300 mah Mamba Max CC BEC My dig wiring. ![]() Thanks for looking.
__________________
The Hotness Project X Vader Last edited by hitman46mod; 05-15-2009 at 04:49 PM. |
| Sponsored Links | |
#2 |
Great looking setup
Nice work on the chassis I really need to get some softer springs for my GTR shocks! What weight oil are you using? That is amazing to me that you don't run any added weight I am running Eritex adjustable off-set wheels with Chisel's and Ace's Donuts with 8oz. front and 6oz rear added. Do you run breather holes in your wheels? Last edited by Xtant3150c; 05-13-2009 at 11:28 PM. |
#3 |
Did you make the climb in the last picture?
__________________
not for hire. |
#4 |
prety damn sweet looks real good
__________________
HD Losi comp crawler, HD Honcho HLOMES POWERD! Black Label Crawlers, top notch! |
#5 | ||
Quote:
Yep. ![]() Quote:
I have a vid of my AX-10 pulling a steep climb with no wheel weight. I'm of the school of thought that a light rig is a good rig. My bully rig only weighs 6.2 lbs. RTR. I use Delrin and stainless hardware keep the weight down. ![]() Here is one of my favorites a 1 1/2 foot leap from rock to rock.
__________________
The Hotness Project X Vader Last edited by hitman46mod; 05-15-2009 at 04:44 PM. |
#6 |
Reworked suspension and chassis. It like a slinky.
__________________
The Hotness Project X Vader Last edited by hitman46mod; 01-10-2010 at 07:30 PM. |
| Thread Tools | |
| Display Modes | |
