10-07-2009, 06:15 PM | #1 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
| Redcat RS10 revisited
Most of the threads regarding these rigs have died out recently and haven't been updated. I've seen a few posts by new members asking about them so instead of posting in those and seeing back and forth opinions between RS10's, axials, and losi's, I decided to make this post so hopefully other RS10 owners can show their rigs in their current forms in hopes that new members can see the potential with them. It could also be a place that can show potential replacement parts and aftermarket parts that will fit them. With that said, here's mine. Mods are as follows: -HB rover tires in white compound with proline memory foam -removed the "wings" from each axle and 4-linked the upper links -cobalt 13 turn motors front and rear with 10t pinions -hitec 645mg servo up front with aluminum horn -locked out rear steer -stripped the bronze color from the stock beadlocks and added weight to each wheel -blue aluminum lower links with holes drilled and tapped for shocks to mount to (purchased from ebay) -homemade delrin upper links -homemade delrin chassis/skid plate -traxxas tq3 radio/receiver combo -axial xc-1 body -wiring mod mentioned in some of the RS10 posts -stock RS10 shocks set up in full droop with 100wt oil and stiff springs So far I'm really happy with this setup...it crawls really well. I've only ran the droop twice so far, so I'm still trying to find the ideal setup for me. The chassis is a work in progress also. This is the first version of it and I went for a simple, but effective look for it. I'm planning on running it for a while, finding out what I like and don't like about it, then making changes on revision 2. The bottom of the skid sits at 2.5" in droop and since I have stiff springs I don't have a lot of flex, barely a soda can worth. Next step is slightly less stiff springs to see how those do. I tried springs from clicker pens the first time I ran droop with this setup and had way too much flex. Here are a few pics (taken with crappy phone camera). The velcro strap in the first pic is where my battery goes. I incorporated a "cradle" of sorts into my chassis for the battery to sit in. Enjoy. |
Sponsored Links | |
10-08-2009, 01:14 PM | #2 |
Pebble Pounder Join Date: Aug 2009 Location: ST. George
10-08-2009, 01:29 PM | #3 |
I got my motors from cermark.com, but they don't have them listed on the website anymore. I'm not sure if they're still available or not. Definitely post up when you get the banebots. As far as the gears are concerned, mine are still going strong even with the cobalts. I've had no problems with anything in the axles yet.
10-09-2009, 08:30 AM | #4 |
RCC Addict Join Date: Feb 2006 Location: Bellflower, CA
Are those 540 sized motors? My brother in law just picked up two of these for his two sons and this post will make him very happy. It looks 10x better than it does in stock form. Did you ever think of picking up some sort of used chassis I.E. axial side plates, mayhem ls2, black widow MFM, etc, etc. The prices arent that bad for these. Or, you could call Venom racing (makers of the Creeper) and pick up two side plates for 8.99 and make you own skid. I think thats what im gonna tell my bro to do.
10-09-2009, 08:34 AM | #5 |
Rock Stacker Join Date: Jun 2009 Location: Austin
Looks good - I wish the Colbalts were back in stock - keep up the updated posts.
10-09-2009, 09:08 AM | #6 |
ser3100, they're 400 motors and are the same size as the stock RS10 motors. There's been a post about running 540 size motors in these rigs before, apparantly the stock gears don't last too long with them. I'd suggest shopping around for a 380 motor...maybe try banebots or something similar. I never really considered picking up an existing aftermarket chassis for this thing because I'm a fan of building things on my own. Maybe in the future if I can't get my delrin chassis to turn out how I want it, I'll pick up a nice existing chassis. austexjg, how is yours holding up? |
10-10-2009, 09:54 AM | #7 |
Everything is okay - after I replaced the stock servos - I run it daily in the backyard, with no problems. I have been thinking about a new chassis, but can't decide which one to try?
10-10-2009, 12:31 PM | #8 |
Quarry Creeper Join Date: Oct 2008 Location: Southwest VA
Looking good I see you got the the cobalts working. Were you using that chassis when I was up there? We all need to get together and hit the dam spot again soon.
10-10-2009, 12:40 PM | #9 |
Nah, I wasn't running this chassis when we all crawled at the dam. I've ran it about 3-4 times total and so far it's working out really well. We definitely need to plan another get together at the dam. Anytime you wanna come up, definitely let me or Adam know. austexjg, if you're into making parts, I would suggest picking up some delrin and making a chassis. It works out a bit cheaper than buying a pre-made chassis, but I doubt you could go wrong with any of the MOA chassis that are available. |
10-10-2009, 12:56 PM | #10 |
Your rig did really well then. I guess it is even more capable now. I have plans for tomorrow but they are not 100%. If they fall through would you all want to hit the dam tomorrow? I won't know till later this evening.
10-14-2009, 08:48 AM | #11 |
Rock Stacker Join Date: Oct 2009 Location: Jersey
Can you run a 3s lipo to the stock esc/motors?
10-14-2009, 09:09 AM | #12 |
Not sure, to be honest. I'm no longer running the stock motors for one thing, and as of right now I'm running a 3300mah nimh battery. I would suggest e-mailing redcat about their stock esc with lipos or check the other rs10 topics and PM some of those guys to see if they're running them yet.
10-15-2009, 10:16 AM | #13 |
I just mounted up my BaneBots 390 last night hopfuly I will have pics and a test this weekend.
10-16-2009, 08:29 AM | #14 |
How did the banebots fit? How did they compare the stock?
10-16-2009, 09:09 AM | #15 |
| They are a little longer then the stock motors. I had to move the lower link on one side of the axle out alittle bit and it is stil pretty close. They bolted right up to the axle with no problems what so ever.
10-17-2009, 11:49 AM | #16 |
I just wired mine up as stated in other threads (connecting motor yellows together to yellows on motor..same w/ blue) and put a bec in to run a 2 cell lipo. Now it wont start from a stop smoothly..it jerks so I keep applying throttle then it will stop and just take off. Doesnt do this with the stock battery. Does anyone else run the stock electronics with a 2 cell lipo? Could it be the stock esc cant run voltage that high? I have read somewhere someone running a 3 cell lipo on stock esc.
10-17-2009, 04:34 PM | #17 |
Newbie Join Date: Oct 2009 Location: Waynesboro
i checked out cermark and they only got dragonfly motor now, just one motor. the banebots 390s. i'm thinking about getting them. are they the RS-390- 12v?
10-19-2009, 08:29 AM | #18 |
newtoy, did you have a chance to run your crawler with the banebots yet? bl8zn, I'm not sure about running lipo with the stock electronics...check some of the older rs10 posts and see if there are any posts about lipo. You could also try e-mailing redcat to see if they have any info. |
10-20-2009, 02:20 PM | #19 | |
| Quote:
10-20-2009, 05:02 PM | #20 |
Quarry Creeper Join Date: Nov 2006 Location: omaha
Well here is my RS10. Its my first crawler, and I took it to a local comp and failed horribly. I've never crawled before and I couldnt use rear steer. But I plan on locking out the rear steer, and I wanna add a dig much like this one My Dig Switch Box! I wanna know how to add a switch on my remote to run the dig unit. I would like it to take place of the rear steer servo. But heres a picture of mine I also have a video. http://www.youtube.com/watch?v=L6UWgfaSivk |
