Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Redcat RS10 revisited
Old 11-09-2009, 04:50 PM   #61
Originally Posted by bl8zn View Post
Here's a couple more with the lid off.....
Are thoes stock shocks?
newtoy is offline   Reply With Quote
Old 11-09-2009, 05:18 PM   #62
Yes they are. I'm running internal springs under the piston along with losi white springs on the outside. 1/2 droop 1/2 sprung? Ride height is exactly 3 inches. It works really well IMO.
bl8zn is offline   Reply With Quote
Old 11-09-2009, 05:42 PM   #63
Looks good - pictures are working..
austexjg is offline   Reply With Quote
Old 11-09-2009, 06:01 PM   #64
I like it. Did anyone get the banebots working yet?
jsowens is offline   Reply With Quote
Old 11-09-2009, 06:34 PM   #65
Those are Banebot 390s in my pics. I burnt the stock motors shortly after getting the rig. The banebots perform decent but Im definitely looking for an upgrade. Maybe the Holmes hobbies 454 pullers. The only thing is they are about 4 mm longer than the banebots and with them I have no room already
Old 11-09-2009, 08:53 PM   #66
Very very nice redcat!!!!!!!!!!!!!!
derek_18mt is offline   Reply With Quote
Old 11-10-2009, 07:10 AM   #67
The banbots are ok with 3 cell lipos.. but they rotate 1/2 turn for a redcat full turn.... much slower... but alot more torque
tjmark is offline   Reply With Quote
Old 11-10-2009, 08:47 AM   #68
Are you useing the stock ESC with the 3s lipo? I didn't think it would take the voltage.
Old 11-10-2009, 10:07 AM   #69
I'm running a 3s...no problem so far.
Old 11-10-2009, 01:33 PM   #70
Here's my new radio. Not really new...I use it on my helis. Pen springs on throttle to return stick to center. Easily goes on and off when I want to fly my helis. Programmed in all steering modes like stock radio but now I can add front/rear dig and control another esc if I decide to go that route.
Now I just have to get used to the controls but man what control
Old 11-11-2009, 07:04 AM   #71
This is a good thread, now maybe I have some motivation to play with my RS10 again.
So in short....no one has really found better motors
Wiring mod help slightly with clod stall
Drooping is the way to go
Change out "wings" on top of axles to some sort of custom 4link setup
nics1152 is offline   Reply With Quote
Old 11-11-2009, 09:20 PM   #72
Default Pinion pitch
What pitch pinion gears does this thing take? Are they 48 pitch or something different?
WKKILLER is offline   Reply With Quote
Old 11-11-2009, 10:16 PM   #73
x2...
frdtrkguy is offline   Reply With Quote
Old 11-12-2009, 05:14 AM   #74
Default motor option?
Hey newbie here, my rs10 is on the way. Just wondering if this might be an option for the motors. http://www.hobbypartz.com/alpha-370-...ess-motor.html
cul8tr is offline   Reply With Quote
Old 11-12-2009, 07:10 AM   #75
Yep, the pinions are 48 pitch. I picked up a pair of 10t pinions from rc4wd when I got new motors for mine. Here's a link to the ones I got.
http://www.rc4wdstore.com/2/product_...roducts_id=197
cul8tr, not sure on the motors. Those could be more of a high speed motor than a crawler motor, and I think you might need a different ESC for brushless also. Maybe some of the folks with brushless experience will chime in with info.
Old 11-12-2009, 09:17 AM   #76
Thanks for the info
Old 11-14-2009, 07:24 AM   #77
is there a way that you can change the stearing knuckle
here is some pics of my redcat rs-10.
I have changed:
Motors = axial 55t
Servo = hitec 7955
Frame = home made
Tires = pro-line chisels
Rims = pro-line 8 shooter
ESC = mamba max
Dig = punk RC Dig
body = pro-line , C-10 and Rockstar
cvona is offline   Reply With Quote
Old 11-15-2009, 12:05 AM   #78
CVONA> What do you think of the larger motors?
Is there notiacable power or speed now? or both?
I am thinking of going to novak 55 t motors just want to make shure it makes a big diffrence?
Thanks
Old 11-15-2009, 09:35 AM   #79
How does the dig work in this rig? Looks awesome.
Old 11-15-2009, 11:32 AM   #80
Rig's lookin good, cvona.
I'm curious how the dig is workin out for you also. As far as changing steering knuckles, I would imagine that some of the aluminum aftermarket knuckles would work well, or would work with slight modification.
Next steps for my RS10 are: revision 2 of my chassis, dig switch box (the one stickied in the berg forum), possibly trying to re-configure my steering so my steering links don't get all beat up.
