01-09-2013, 07:04 PM | #1 |
Rock Stacker Join Date: Nov 2011 Location: Summerville SC
| Such a thing as a 1/10 scale carrier bearing?
Heres my problem. On my current build(still in planning, not actually started) I need a carrier bearing of sorts. The wheel base is so long, no driveshafts will work with the scx10 tranny to reach the scx10 axles... So i need to run a third driveshaft, basically two shafts to the rear axle. If any one knows where i can buy one, let me know. I have a plan to kinda fab one, but it gonna be a pain...
01-09-2013, 07:22 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
| Re: Such a thing as a 1/10 scale carrier bearing?
I looked at some on the McMaster-Carr website yesterday that I think would be great, look up (pillar block bearing) |
01-09-2013, 07:37 PM | #3 |
Quarry Creeper Join Date: Jun 2009 Location: South Crawl-o-lina
After seeing some of rbgerrish's builds (dude is a genius), I have seen him use some longer shafts. Such as on this build: Dorkstar Productions Presents: The Argus FPV Otherwise, if you're not running some big horsepower, I would suggest cutting up some Traxxas shafts using the cut shafts as connectors and some CA glue to make a longer shaft. I have used 2 male ends and cut the joint end off a female to use it as a coupling before on a longer wheelbase rig. |
01-09-2013, 07:46 PM | #4 |
Quarry Creeper Join Date: Sep 2007 Location: No Cajones en El Cajones
Cut up an Axial trans and just use the bottom half of it. That way you can even mount it with the four holes where you want it for support.
01-09-2013, 07:54 PM | #5 |
Rock Crawler Join Date: Dec 2010 Location: Piedmont, SC
Another option is to cut and weld a section into a mip shaft (the male end) you should be able to find some round stock that is the same size.
01-09-2013, 08:00 PM | #6 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
I see them on rc semi's every once and a while, someone makes them.
01-09-2013, 08:07 PM | #7 | |
| Re: Such a thing as a 1/10 scale carrier bearing? Quote:
I guess it will depend on ride height and pinion angle to know if this strategy will work for ya. X2. Just remembered seeing those as well. | |
01-09-2013, 08:18 PM | #8 |
Rock Crawler Join Date: Oct 2009 Location: Columbia, SC
How big of WB are you talking? max usable length(quarter inch engagement) fully compressed This is what I have on the silverback. WB is a little over 14". I think its a revo shaft, not sure but I can get the part # if you think it might be long enough. |
01-10-2013, 05:32 AM | #9 |
Creepin king, Yes, please get me the part number, You can PM me or put it here. Thank you!!!!!!! Cheatin, thats what my plan was if I couldnt get a purpose built one. Thanks for all the info guys!!!! |
01-10-2013, 05:43 AM | #10 |
I'll dig around this afternoon after work and get it for ya. Also if you needed a little more length than that you could use the wraith outputs on it too. Probably pick up another half inch.
01-10-2013, 06:20 AM | #11 |
| Re: Such a thing as a 1/10 scale carrier bearing? |
01-10-2013, 06:31 AM | #12 |
Quarry Creeper Join Date: Jul 2009 Location: Cherokee, NC
Those MIP shafts are a timesaver when it comes to long wheelbase rigs. I've needed them especially with offset punkins on Wraith axles...
01-10-2013, 02:06 PM | #13 | |
| Re: Such a thing as a 1/10 scale carrier bearing? Quote: | |
Such a thing as a 1/10 scale carrier bearing? - Similar Threads | ||||
Pinion carrier bearing issues | arnesto | RC4WD Trail Finder 2 | 21 | 02-14-2017 08:58 AM |
Who Can make a carrier bearing???? | balln | General Scale Talk | 9 | 07-22-2011 09:33 AM |
They say its a scale thing! | BCCrawlerZ | 2.2 Scale Rigs | 4 | 06-11-2008 09:33 PM |
