Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > SSD Trail King - Pro Scale Chassis Builder Kit
Thread: Gear Ratio on Overdrive Pinion/Ring gear set?
Old 08-08-2020, 07:02 PM   #1
Default Gear Ratio on Overdrive Pinion/Ring gear set?
Looking for the gear ratio spec on the overdrive set of gears.
Isn't it pinion divided by ring tooth count? Or is it the other way.
Been too many decades since I thought about this stuff. lol
I think it is about a 3.37:1 ratio, but figured I should ask.
Timmahh is offline   Reply With Quote
Old 08-09-2020, 06:38 AM   #2
Default Re: Gear Ratio on Overdrive Pinion/Ring gear set?
You are correct. Ring gear/pinion gear.
OD: 27/8=3.375
Stock: 30/8=3.75
((3.75-3.375)/3.75) *100 = 10% overdrive
OSRC is offline   Reply With Quote
Gear Ratio on Overdrive Pinion/Ring gear set? - Similar Threads
Pinion gear and ring gear mesh question flyboy320 Axial Wraith 18 01-09-2016 02:41 PM
Diff ring/pinion gear ratio? tetracanth Tamiya TLT Crawlers 2 01-06-2010 12:16 PM
RS4 pinion and ring gear set-up... chris_dishmon HPI Wheely King 39 12-26-2009 05:41 PM
