11-09-2009, 07:00 PM | #1 |
Quarry Creeper Join Date: Jan 2005
| Tranny for super shafty?
Building a super shafty rig. I've made/collected all the parts except the transmission. I have a few ideas for what transmission to use, but I would like to get some ideas and suggestions here as well. It weighs just under 8 pounds without the transmission and battery. Thanks a lot for any input or experience you have on this. Pertinent specs: 17" wheelbase Twin Force axles w/mods Vertigo lockers Steel helical 43/10's and 43/13's (may overdrive the front with the 43/10's) Revo shafts 6.75" tires 4 link suspension 4WD / 4WS Lightweight custom TVP chassis Machined center skid/transmission mount/lower link mount (haven't drilled holes for trans yet) |
11-09-2009, 07:01 PM | #2 |
Hateraide Join Date: Dec 2008 Location: Mission BC
ive seen guys use built axial trannys or an emaxx tranny
11-09-2009, 07:12 PM | #3 |
RCC Addict Join Date: Apr 2004 Location: 5280
I run a R2HD in my TXT axled super. So far so good, no problems with it at all.
11-09-2009, 09:31 PM | #4 |
What's the weight on your TXT axled super?
11-09-2009, 09:51 PM | #5 |
Rock Crawler Join Date: Sep 2008 Location: Portland
Id run an axial. Just put some heavy duty outputs and you'll be good!
11-10-2009, 02:50 AM | #6 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Axial tranny with alloy gears and CDW 6mm outputs Kieren |
11-10-2009, 03:54 AM | #7 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
get ahold of chrisjlittle, I know he is building similar and has tons of stuff to build with. my vote would be AX!10 HD out put shafts alum gears in an alum trans case.
11-10-2009, 04:43 AM | #8 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
I am running an R2HD in my force based super. Total weight is 8lb 1 oz RTR. I have no problems so far and reduction is around 45:1.
11-11-2009, 09:36 AM | #9 |
11-12-2009, 01:23 PM | #10 |
Pros and cons running built Axial vs R2HD in the super?
11-12-2009, 01:32 PM | #11 |
RCC Addict Join Date: Jun 2006 Location: Maryland
11-13-2009, 08:23 PM | #12 |
What or who is the preferred source for Axial tranny buildup components?
11-13-2009, 09:04 PM | #13 |
Quarry Creeper Join Date: Jul 2006 Location: Huntspatch
I know RRP (Robinson Racing Products) has AX10 HD tranny gears-
