03-12-2010, 09:32 PM | #21 | ||
Pebble Pounder Join Date: Feb 2009 Location: LeMars, Iowa
They are kyosho rock force axles. Make sure you do a write up as you build your rig man, it's a great way to show what you can (or can't in my case) do, and get some advise/tips/suggestions along the way. Not to mention helping other people that may be looking for things to do to their own project(s). I have to say the Hustler chassis and I have love/hate relationship. Has, and still does, show to be a proven setup that works well for alot of folks. Mine should be going under the cut off wheel soon for some rework of things that bug me about it. Suggestions on the clod axles? I can only tell you what I run and what works for me. JP customs knuckles, Thundertech 8mm cvd shafts, Aluminum axle tubes, ball bearings all around, plastic gear case halves, Integy gears, HR adjustable motor mounts, and last but not least, hand (re-)wound 55t motors. Good luck with it man, keep us posted! | ||
03-12-2010, 10:41 PM | #22 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
Lookin' good man, what wheel adapters are those?
03-14-2010, 08:19 AM | #23 |
Wish I could tell ya who made them, I'd get another set. Picked them up in a package deal awhile back. I know they will fit on clod axles with 8mm shafts, but the pin size is way to small to put any power to. I've had them laying around with the intent of never using them, until now! |
03-15-2010, 11:38 AM | #24 |
Picked a color scheme for it, will have to make some new body panels and what-not. |
04-23-2010, 07:54 PM | #25 |
Just an update for what it's worth. Have been running it around (read:carpet crawling) and learned a few things. Managed to quick fab up some aluminum body panels as well. 1. Stock steering servo mount will have to be upgraded, only holding a servo on by 2 screws = a lot of broken servo mounting ears. Who would have thought..... However, the BTA works good. 2. There is VERY little room in a Hustler chassis after you put in a tranny. Mind you I used the stock setup, can't see it working in this chassis with any other trans, unless it has = or < the same foot print. 3. 96t spur-13t pinion, 30:1 gears, crap 55t, and 7.2v = slow and under powered. Running it on 14.4v yielded good wheel speed and so-so power. 4. A crap 55t motor can let out a surprising amount of smoke. 5. Will have to try and make a front 4 link mount, using the plastic single link mount and spacing it over works, but there is far too much flex to be taken seriously. 6. Torque twist and the lack of Clod stall take some getting used to. 7. With the only real usable space in the Hustler eaten up by the tranny, finding good real estate for battery placement is going to be a pain in the arse. Can't beat it on the rocks with batteries velcro'd to the lid... In all honesty, this project will probably be coming to a close in the near future. Might just keep it on the back burner, but can't see any other real progress being made any time soon. |
04-26-2010, 08:28 PM | #26 |
Back burner, but not dead yet. |
