02-21-2010, 10:12 PM | #1 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
| 40 series LOW PRO ROVERS
Wasn't sure if this should go here or tires, but i prefer this newer section. I have been trying to put together the clod axles, just cause i cant get the dough for super bullys. I didnt like the sidewall height of the moab xl's and preferred the regular moab 40's. So i had these sitting around and thought i would try this. It's pretty low but i think i like it. Any one else ever tried anything like this? Any success? And what downsides do you guys see i will run into when i finish this rebuild? These are on Narrowed cheyenne's |
02-21-2010, 10:42 PM | #2 |
Pebble Pounder Join Date: Apr 2008 Location: In a state of eternal chaos
What the hell did you do? Is that a 2.2 tire stretched over a 40 series rim?
02-21-2010, 10:46 PM | #3 |
HA no I didn't stretch a 2.2 tire, i did that age old super crawler tradition and cut a tire. hopefully that explains it a little bit more. they SHOULD sidehill really well. But time will tell |
02-22-2010, 12:03 AM | #4 |
Does the bead ring hold the tire without a tire bead? Low profile tires allow for softer foams without the huge sidehill effect of a large sidewall tire, but I think this may be an extreme of that principle. I like the idea, but would want a bit more sidewall. Maybe the same OD but on a 3.7 LPR Truggy rim? I would guess they will still work pretty well, only issues being that you get rim to rock contact often. Not allowing for the tire to "hook" ledges and such. But who knows, run them and report back. |
02-22-2010, 06:06 AM | #5 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
What you need to do is grind some groove into the ring so they act as your side lugs...lol
02-22-2010, 12:49 PM | #6 | |
I Still have 2 wheels to narrow so i am thinking i will make them narrower than the wheels in the picture so i can get a little more sidewall than run those in the front. | |
