Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: Tuner's superbully
Old 11-14-2011, 07:31 PM   #1
tuner's Avatar
Default Tuner's superbully
65.1 super bully axles
torquemaster 45 turn motors
mamba max esc with punk dig
7980 front 7950 rear servos
chaotic crawlers chassis
big bore shocks
7" tall rovers on 3.8 plastic wheels
2250 3 cell
4pl
tuner is offline   Reply With Quote
Old 11-14-2011, 08:50 PM   #2
Awsome pics!
Nice rig too.
Psychomonkey RC is offline   Reply With Quote
Old 11-15-2011, 04:09 AM   #3
Looking good.
Rckcrwlr is offline   Reply With Quote
Old 11-15-2011, 05:08 PM   #4
Looks good Tuner. I am so glad a bunch of us are building supers now. It will be another fun thing at our already fun comps. Can't wait to get mine done and more idea's to tune and dial it in before our next comp.
Lil Digger is offline   Reply With Quote
Old 11-26-2011, 10:02 PM   #5
tuner's Avatar
I have changed a few things sence utah state champs. I have 8" roverXL's with losi 17mm hexes now and I made some knuckle weights that weigh 10.7oz loaded with bolts and nuts. It climbs allot better now but with all that weight up front i might have to take some off or add some weight to the rear because the rear tires lift allot more.
Old 11-26-2011, 10:51 PM   #6
Looking good and nice idea on those knuckle weights.
Gear Jammer is offline   Reply With Quote
Old 11-27-2011, 07:21 AM   #7
666
MODERHATER™
666's Avatar
I like the weights!! I never got to see you run in Utah, that was a great comp!
666 is offline   Reply With Quote
Old 11-27-2011, 08:06 AM   #8
Nobody
Cordwood's Avatar
Those knuckle weights are slick. How do you secure them to the knuckle?
Cordwood is offline   Reply With Quote
Old 11-27-2011, 09:34 AM   #9
tuner's Avatar
I put a short 2mm between the knuckle and the washers. I got all the stuff from home depot and if you can weld its pretty easy.
Old 12-22-2011, 10:44 PM   #10
tuner's Avatar
Default Re: Tuner's superbully
I decided to try a bta steering setup and this is what I came up with. It works quite well. All I did was flip each knuckle over so that the arm is behind and low on the back side of the axle then mounted the servos backwards.
Old 12-22-2011, 11:00 PM   #11
Wanna get? Gotta want.
Erik D_lux's Avatar
Looks good.
What is your overall width?
How can I find some of that foam you were using? Is there a special name for it? I would like to get the same stuff you were using when I was checking it out at Little Moab.
Erik D_lux is offline   Reply With Quote
Old 12-22-2011, 11:18 PM   #12
tuner's Avatar
Originally Posted by Erik D_lux View Post
Looks good.
The foam is joann fabrics 15x17x2 foam. I think its a medium density but im not sure on that. You need 2 of them if you have 8" tires. nThe width is 13.5"
Old 12-23-2011, 03:14 AM   #13
Very simple but effective knuckle weights - look great
Arct1k is offline   Reply With Quote
Old 12-24-2011, 11:35 PM   #14
Great idea with the knuckle weights Like the BTA steering.
Merry Christmas and regards
Dani
nicodrive01 is offline   Reply With Quote
Old 01-08-2012, 06:58 PM   #15
tuner's Avatar
This rig has been working well for me and I love driving it. I ended up getting 1st at the last 801rcc comp. Thats not saying much in 801 because there are only like 4 of us with supers. There is always room for modifications though so I changed a few more things.
1/4" solid steel links
different front shock setup so the shocks are mounted to the axle instead of the lower links
more braces in the chassis
stronger front droop springs
stiffer rear springs
reconditioned motors (they needed it) Thanks Murff dog
Old 01-08-2012, 07:03 PM   #16
666
MODERHATER™
666's Avatar
To me it's just awesome there are 4 supers in Utah now, they are multiplying!!
Rig looks hot, nice and solid.
Old 01-08-2012, 08:07 PM   #17
you should watch them they sneak off at night and make baby crawlers and then they grow
asw27x is offline   Reply With Quote
Old 02-16-2012, 11:11 PM   #18
tuner's Avatar
A few pics from our last comp. I also added a 7980 to the rear before this comp.
Old 02-03-2013, 06:22 PM   #19
tuner's Avatar
Got some new skinz from krawler konceptz.
Old 02-04-2013, 07:51 PM   #20
Erik D_lux's Avatar
Where are those rocks at?
