08-08-2012, 09:28 AM | #1 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
| DioptricStraws Super Juice
Thought I would start a build thread for my super juiced bully. Parts list: 65:1 light weight super bullies Super Juice Chassis traxxas 2662/2661 shocks with modded caps. (green mini-t rear and 30wt up front, blue mini-t rear and 40wt rears) Futaba R2104GF and my 4PL Twin squished axial AE-2 Brood 45t 3 CC BEC 2 Power HD DS8325HV servos up front 7980 in the rear Home brew links with revo ends all round Dlux tubes in the rear with a 7980 servo mount Front knuckle weights are from a member on the RC4WD forum Light wieght 17mm buggy hexes from the HB D8 Narrowed HPI Blasts (Chrome was all the LHS had) Moab/rovers with CI foams Right now the front tubes and rear case are on their way to Dlux to have some weight removed. These are the only pictures I have of it assembled for right now, more to come when I get the parts back. |
08-08-2012, 09:47 AM | #2 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| Re: DioptricStraws Super Juice
Nice start ya have there , I'm getting ready to start my super juice Bully build as well and would like to see some pic's of your link setup. Will be watching.
08-08-2012, 10:15 AM | #3 |
Newbie Join Date: Aug 2011 Location: akron
I like the front servos step up, all the way to the end of the axle. I've been looking for a better front steering option for my super juice... what kind of mounts did you use for that.
08-08-2012, 05:11 PM | #4 | |
| Re: DioptricStraws Super Juice Quote:
Here are some pics as it sits now, remember there is no front axle. You can also see some of the shaving I did on the rear case (which is gonna be the front case when I get my other one back), I removed the top screw hole as well. In the last pic you can see the buggy hub/nut and the link mounts for the Dlux tubes. | |
08-08-2012, 05:15 PM | #5 | |
The Servos I am using are full aluminum cases so mounting is fairly easy. All I did was stand them up against the link mount, drill and tap 2 holes and tada. The center link is gonna be replaced with a turnbuckle (if there is a big enough one) and a link to tie in the tops of the servo cases will be added. | |
08-08-2012, 05:22 PM | #6 |
Sorry to get away from the build, but creeperbob how does your jig work and could you put a quick pic. Im thinking this is something ill be needing!
08-08-2012, 05:34 PM | #7 |
Totally awesome idea .. yeah a little support on the top of the servos would prob be good insurance. |
08-10-2012, 05:50 AM | #8 | |
What the Jig does is give you a guide to drill a second set of holes in the axle tubes for you to clock the axle. Clocking allows more caster to be run while still keeping the gear case up and out of the way. Here is the jig and here is is bolted up some grinding will be required | |
08-10-2012, 06:58 AM | #9 |
Ahh, very nice that's gonna have to be on my list of things to do. Were those delrin links easy to bend ? I want to go with delrin for my lowers just looking for the best way to do it. |
08-10-2012, 07:26 AM | #10 | |
They are actually all-thread sleeved with brake line. For delrin you would be better off cutting them from a sheet in the shape you want, similar to the links you get with the BWD super wedge (whick is what mine are based off of) | |
08-10-2012, 08:08 AM | #11 |
The brake line is black an flexible? I Don't think I've ever seen that type before? Great idea!
08-10-2012, 08:20 AM | #12 |
| Re: DioptricStraws Super Juice |
08-10-2012, 08:46 AM | #13 |
How thick is the threaded rod?
08-10-2012, 07:55 PM | #14 |
The rod is 8-32 all thread
08-10-2012, 10:03 PM | #15 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I would be worried about the servo mount. You will rip them loose mounted only from one side.
08-11-2012, 05:38 PM | #16 |
A stronger servo mounting option or anther piece to beef it up will be worked on when I get the tubes back.
09-01-2012, 03:55 PM | #17 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
I was wondering if you could tell me how much weight you saved having your rear axles machined by dlux? Build is looking great btw |
09-01-2012, 05:45 PM | #18 |
DioptricStraws Super Juice - Similar Threads | ||||
Super juice | GREEDY GENIUS | Superclass Crawlers | 1 | 04-04-2011 10:15 PM |
Super Juice.... | Arct1k | RC4WD Bully | 31 | 01-28-2010 07:54 PM |
