09-25-2014, 05:22 AM | #1 |
Newbie Join Date: Apr 2010 Location: Taylors Falls
| any integy hop-ups
I got a Integy crawler (1/8 the scale) any hop -ups for it?
09-25-2014, 09:03 AM | #2 |
Rock Stacker Join Date: Jul 2014 Location: Littleton
| Re: any integy hop-ups
Did you get the iRock model AFA01?
09-25-2014, 09:09 AM | #3 |
Axial AR60's Axial transmission |
09-26-2014, 06:26 PM | #4 |
Yes I did. So far its been cool no problems
09-26-2014, 08:45 PM | #5 |
RCC Addict Join Date: May 2012 Location: Folsom
Pics?
09-26-2014, 11:00 PM | #6 |
So what you have is a MOA with a TVP chassis. Here is what I would start off with. Make sure you have grease in the gearbox and check to see if you have metal or plastic gears. Look to see if the tires are conforming to the obstacles you are driving over and possibly change or modify the foam in the tires. Adjust spring rate and/or oil in the shock to better fit your driving style. Relocate battery to lower CoG, I would probably mount it over the front axle. If your chassis has holes pre-drilled to allow for adjustment of shocks and links experiment with them. Now to spend your money. Stronger servo and servo arm, maybe add 4ws, different wheels and tires, pickup a different chassis like an old Frankenstein, make links to fit the new chassis, better motors and esc, big bore shocks, mod the axles for better steering. The axles on your crawler are the same design as the Exceed Maxstone, some HSP models and a host of others. Your options are only limited by your wallet. Have fun!
any integy hop-ups - Similar Threads | ||||
Integy hop ups | Taper | Axial Wraith | 14 | 04-22-2012 09:34 AM |
R1 Hop Ups | Steve Hipsley | G-Made Crawlers | 2 | 05-19-2010 08:29 PM |
hop ups | Mr.Slave | Axial AX-10 Scorpion | 5 | 08-06-2008 09:33 PM |
