Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya Bruiser
Thread: LowslowTJs Bruiser Re-re
Old 04-18-2013, 02:00 PM   #1
Default LowslowTJs Bruiser Re-re
So as a child of the late 80s and 90s I always wanted a Bruiser, but never had the dough for one. I was ecstatic when I heard about the Re-re and ordered one up from RPP a while back. I went through most of the build a while back when I was on a break with RCC never posted any pics. I did not build it exactly as a box art kit that is for sure. Its gonna be a 1.9 crawler. Here are some pictures of where it sits now with some of the details that I changed from a straight up build. everything was home built except I added an RC4WD 12mm Hex conversion (that went on the kit seamlessly) and some 1.9 wheels and tires I had sitting around. Hope it helps other people with ideas for their builds. Eventually I'll build rock sliders, bumpers etc.
With any luck I'll hopefully have time to keep building it and update this thread occasionally. All my inspiration are from the realistic looking Hilux clones out there 1Badjeepbruiser's many Luxes, Im also steeling ideas from Chino and others. Thanks for the inspiration!
Here she sits as I type this:
The front suspension is stock with spring-over axle set-up. I flattened the springs and Chinoed the spring eyes. I think these things sit to high and obviously I am going with 1.9s
Outback I am running Chinoed springs spring-under to lower the suspension a little. Also rear axle wrap is generally less of a problem in rigs with spring-unders...at least in the 1:1 world. We'll see how it works on this rig once it is a runner. My plan is to tweak things like the suspension once I get some scale miles on it:
I also lifted the drivetrain up a little to help achive a more flat belly. Up front I used some spacers that came with the kit:
Outback I made a plate that moved the rear mounts down the same amount as the front was lifted. I can now make a flat belly skid that will cover the "T-case" and most of the trans:
I also lowered the body mounts so the body will sit a bit lower on the chassis. I still need to make the front lower body mount. I shortened the factory front body mount, but its gonna interfere with the motors new higher position. I am also gonna have to mod the interior to clear the higher drivetrain...or not run an interior.
Thats all I've done as of now...but I have ideas for the steering that should give others some ideas. I may also run a slightly modded and bobbed box art body...I even contemplated making some metal brazed tube style bumpers for this thing...maybe.
lowslowTJ is offline   Reply With Quote
Old 04-18-2013, 05:56 PM   #2
Default Re: LowslowTJs Bruiser Re-re
Damn Verne nice comeback project, liking it
Ghost is offline   Reply With Quote
Old 04-19-2013, 10:54 PM   #3
Boobed the body and trimmed the front a touch...as if no one has ever done that before!
and Body placed on chassis...still need to build the front mount.
and a Glamor shot:
Old 04-21-2013, 02:07 PM   #4
Little more:
I flipped the shocks and added some more traditional eyelets. I also eliminated the front u-bolts and countersunk the lower spring mounts so the hex head bolts wont catch as much.
and front body mount:
And i need to trim the body or find some smaller tires:
Old 04-21-2013, 04:20 PM   #5
I decided to push the front axle forward a touch.
I did this by making centerpin offset plates:
this pushes the front axle forward ~5mm?
Here are my countersunk screws:
Old 04-22-2013, 07:11 AM   #6
Looking great
redjones is offline   Reply With Quote
Old 04-23-2013, 03:22 AM   #7
Cool build and I mite try the u-bolt flip on my bruiser.
Sent From My 2500 HD Tapatalk 2
rocpede is offline   Reply With Quote
Old 04-23-2013, 09:50 AM   #8
Originally Posted by redjones View Post
Looking great
Thanks
Thanks, yea using the bolts and an upper plate is awesome for ground clearance.
Here is a bit more. I slowly built a front bumper for the rig:
Old 04-24-2013, 10:42 PM   #9
Started some rock sliders:
Old 04-24-2013, 10:47 PM   #10
And I finished them up by bending them up and adding a kicker bar:
Old 04-25-2013, 01:05 AM   #11
Rock sliders look great and you helped me get an idea how I can mount my steps on my bruiser.
Old 04-29-2013, 06:16 PM   #12
Little more:
Steering:
Power:
Modified the factory electric box:
Old 04-29-2013, 06:30 PM   #13
Looks awesome man. The old custom bruiser chassis builds are my favorites.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
adamargue is offline   Reply With Quote
Old 05-01-2013, 08:45 PM   #14
OK, got the body painted...and then re-painted.
First I started with Tamiya TS-15 per the instructions:
The Tamiya paint ran and when dry was all orange peeled. Not shiny at all. Also the can ran out about 99% of the way through the paint job. Boo. Tamiya, count me disappointed with your paint
Here I wet sanded the runs:
Thumbs down on the Tamiya spray paint. I'll have to find an alternative.
Old 05-03-2013, 09:29 AM   #15
Ok, the body is re-painted. I am thinking of adding the box art stickers and painting the tube work white...but then this blue is not really dead on box art blue...then again the tires and wheels are off too so meh who cares.
Old 05-03-2013, 03:13 PM   #16
Looking good Verne
Old 05-03-2013, 03:41 PM   #17
Looks awsome and the low stance is sweet.
Old 05-05-2013, 05:17 AM   #18
everything you did was agreat idea, looks good man
SEMIJOE is offline   Reply With Quote
Old 05-11-2013, 11:09 PM   #19
Sweet build man! Subscribed! You want the spare parts I have from removing my hex conversion? Might be nice to have some back ups. PM me your address and I'll mail them to you...if you want them. Otherwise they're going in the garbage.
JHTreyIII is offline   Reply With Quote
Old 03-09-2014, 12:45 PM   #20
tj you did a really good job, man everything you did was what I want to learn. can you post a picture how front wheel can pull up. from ground to top. by the way I just got bruiser and I bought soft leaf instead of og metal leaf
kcycowboy is offline   Reply With Quote
LowslowTJs Bruiser Re-re - Similar Threads
anyone on here owns an og bruiser/hilux and a re-release bruiser? cartronicshn Chit Chat 1 05-07-2012 03:31 PM
lowslowTJs Rat Rod CR-01 lowslowTJ Tamiya CR-01 14 02-03-2012 12:41 AM
LowslowTJs K2-3L yota lowslowTJ 1.9 Scale Rigs 11 02-10-2009 01:50 PM
tribute to the legendary bruiser/mountaineer RC4WD bruiser el barto 2.2 Scale Rigs 12 11-04-2008 08:12 AM
