01-13-2008, 10:50 AM | #1 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
| Quick TTR CVD question
My TTR CVDs have been on back order since before Christmas, so I have a couple questions on them and the installion. Do they use the standard 5mm E-clips that the regular Clod axles do, to locate and hold them inside the axle tubes? Also, can someone tell me what the outside diameter of the shaft is that passes through the steering knuckle? I need the measurement right where the pin goes through, where the wheel hub or drive hex would be. Thanks. |
01-13-2008, 11:49 AM | #2 |
1. Yes, I believe so. 2. 8mm diameter |
01-13-2008, 12:56 PM | #3 |
01-13-2008, 01:18 PM | #4 |
If you get a set of the Ofna 17mm hexes, they are 8mm ID and then you could get some 17mm wideners and/or adapters and go from there.
01-13-2008, 01:21 PM | #5 |
Quarry Creeper Join Date: Oct 2006 Location: where fear and common sense don't get in the way
Are they set up with the stock 12mm hex. The TTR wheel hex sits at the very end of the axle. I've got 2 different wideners that fit on the axles I have.
01-13-2008, 02:40 PM | #6 |
Well what I have is some Integy 23mm hex, 30mm wideners. They looked like they would work, so I bought them, but I was expecting to have my CVDs a month ago already. I hate waiting for parts! I just want to build the darn thing! Here they are.... http://www3.towerhobbies.com/cgi-bin...?&I=LXRTN4&P=7 Come to think of it, maybe I can just chuck them up in a lathe and enlarge the bore. |
01-13-2008, 04:08 PM | #7 | |
http://www3.towerhobbies.com/cgi-bin...?&I=LXSBA9&P=7 Which means that you will need to drill the centers out to match the 8mm TTR axle specs. | |
01-13-2008, 07:52 PM | #8 |
Pebble Pounder Join Date: Feb 2007 Location: Gloucester
Yes they have 12mm hex , you can get 14,17, also . I'm looking to order a set ,who did you order from ? |
03-24-2009, 04:47 PM | #9 |
Rock Crawler Join Date: Jan 2006 Location: Nebiru, OuterSpace
no answer... so where can you buy the hex adapters to worth with 8mm inner bore? anyone? Seems like everything on Ebay has a 6mm bore. I don't want a widener. Do you just have to bore your adapters to 8mm and 'pin' them to work with the CVD's? That stinks Last edited by WRXronald; 03-24-2009 at 04:53 PM. |
03-24-2009, 05:24 PM | #10 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
I am pretty sure this has been mentioned a bunch...but pretty much all Truggy/Buggy 1/8 scale hexes have 8mm output.
03-24-2009, 06:18 PM | #11 |
Pebble Pounder Join Date: Feb 2005 Location: The Aloha State....Aurite!
Yes they have 12mm hex , you can get 14,17, also . I'm looking to order a set ,who did you order from ? I ordered a set recently from TCS, they have all sizes in stock last time I checked.............. |
03-24-2009, 07:37 PM | #12 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
I got the 14mm wideners from tcs. They fit well with my cvd's http://www.tcscrawlers.com/Junfac-12...1-p-16232.html |
03-24-2009, 10:49 PM | #13 |
Wow, old thread revived! Interesting because I didn't realize it was my thread from last year, until I opened it up, ready to help. I just ended up boring out the Integy wideners, in a lathe, to 8mm. Been working good so far. I really needed the offset so my wheels wouldn't rub the 4 links at full lock.
