01-13-2008, 02:23 PM | #1 |
Rock Stacker Join Date: Dec 2006 Location: Netherlands
| My TLT Clod
I am building a Clod crawler based on a stock TLT chassis. The stock TLT chassis was laying around in the garage after building my TLT tracer brushless. I started with a tuber chassis, but thats not my thing i need a body on my crawler (Tuber chassis for sale ) Orderd some upgrades.. and start building on my TLT Clod. and changed it in to this home made servo mount Upgraded the shocks The roller with body, and custom build body mounts Changed the under links into massive 8 mm alu Update with body Some experiments with the shocks, i still dont know what the best solution is. The beadlocks mounted ( just for the pic, there are no inserts ) The bearings Mounted the bearings and two Team Atlas 60 turns motors. parts that are orderd... and two Towerpro digital servo's regards from the crazy Dutch man. Last edited by SXV 550; 01-13-2008 at 02:39 PM. |
01-13-2008, 08:06 PM | #2 |
Rock Crawler Join Date: May 2007 Location: lacey
wow that thing is sitting sky high! I really like what ya did here, the only thing is the way you have the servo mounted. good job on the mount, but don't you think that it puts the servo a little far out front? I would worry about it slamming into rocks. Itegy makes a nice alumninum servo guard for the maxx trucks, I bet it would save you many servos... http://www3.towerhobbies.com/cgi-bin...?&I=LXMJM5&P=7 nice job! |
01-14-2008, 12:00 AM | #3 |
The servo's are moved to the left of the axles,..
01-14-2008, 08:12 AM | #4 |
Rock Stacker Join Date: Mar 2005 Location: Louisville
it looks to me like your upper links might be too long. I would try to shorten them just a bit to bing the axle back down to level. that way you would not be messing up your steering. but, it could also be the pictures. you are sitting a bit high, like mentioned above. if you do not bring you COG down, it will be roll over city when you are out on the rocks. Good luck with this build. Steve By the way, are those MOAB XLs on standard beadlocks? they look short Last edited by mavicracer; 01-14-2008 at 08:13 AM. Reason: new question |
01-14-2008, 11:23 AM | #5 | |
01-14-2008, 12:16 PM | #6 |
Looking good, have you tested it yet? i ask because i have 5 of my rigs on fm 40 ch acoms radio, and i bought some yeah racing crystals for my receivers and ended with a lot of glitching:neutral:, i only swapped the yeah racing ones for the acoms crystals and the problem was solved.
01-14-2008, 01:29 PM | #7 |
| But what Proline beadlock are they on? they make 2 different ones, one for the MOAB, and one for the MOAB XL. It looks like you have the rims for the standard MOABs, not the XL's. One of the rims is narrower than the other, and by the photos, it looks like the combo might be off, but again, like I mentioned earlier, it might just be the photos.
01-14-2008, 02:56 PM | #8 | |
01-14-2008, 03:02 PM | #9 | |
The Clod is not finishd yet, its indeed a little high but i am working in that | |
01-14-2008, 05:14 PM | #10 |
I am not trying to give you a hard time by any means, but the only reason I ask, is because proline makes 2 different beadlock rims for 40 series tires. one is the Cheyenne, which is for narrow/narrowed tires. The other is the Commando, which is for the standard width 40 series tires. The Commandos are 3.4 inches wide, and the Cheyennes are 3 inches wide. it might not sound like much, but it would give you a little more clearance under the axle. the good news is that you can always narrow them. I run XL's on proline standard rims. They were 3.5 inches wide, and I narrowed them to 2.75. with cut foams and weight, they crawl real nice. hope this helps. Steve |
01-15-2008, 01:36 PM | #11 | |
First i will finish the clod, and try it like this. It is not that high as it looks ,It is even lower than a thundertech rage chassis. | |
01-19-2008, 12:26 PM | #12 |
This morning deliverd two servo's, no waiting for the ESC. |
