01-23-2008, 05:20 PM | #1 |
Rock Crawler Join Date: May 2004 Location: Calgary
| JP Knuckles & Wheel Questions for the Clod Guys...
So I'm working on a wheel/axle/etc combo for my Super Hustler build, and I seem to have run into a road block. So far, I have: -TTR CVD's -JP Customs Knuckles -Axial Narrow Rims (17mm hex) I'm wanting to run sub-c cell knuckle packs, but can't seem to find a wheel adapter that will give proper clearance. I picked up a set of Integy 17 mm adapters (16mm offset), but they don't seem long enough (and on top of that, I can't seem to figure out how to keep the pin in on them). Is anyone running a set-up like this that can offer some advice? |
01-23-2008, 07:13 PM | #2 |
Rock Crawler Join Date: Feb 2006 Location: sunny acres
Nope. But I hope it works for you cause I have the same set up and want to do the same thing.
01-23-2008, 07:48 PM | #3 |
Rock Stacker Join Date: Apr 2007 Location: Columbia
you need the wider integy adapters. They make some that are like 1" wider on each side which will allow you to run them.
01-23-2008, 11:00 PM | #4 |
Quarry Creeper Join Date: Nov 2005 Location: Australia
how are you finding that set up? im going to be running the same set up (just need the rims). you need a rubber ring to keep the pin in the hex. they should have came with rubber rings when you got them. if not, try some elastic bands. |
01-24-2008, 05:42 PM | #5 | |
I looked at the Integy stuff pretty closely, and the widest 17mm adapter for CVD's I found was this one: http://www3.towerhobbies.com/cgi-bin...&I=LXTAZ5&P=SM | |
01-24-2008, 05:46 PM | #6 | |
| So far I can't get it to work..........so I guess that means I hate it! LOL. Quote:
I'm pretty sure I just wasted $25..................... Frick.............. Ideas? Anyone? I really don't want to have to buy Proline rims and new 23mm adapters just to run under-the-knuckle packs................... | |
01-24-2008, 07:00 PM | #7 |
Quarry Creeper Join Date: Oct 2006 Location: where fear and common sense don't get in the way
Do you have a drill press and or a dremel..... All you need is a small groove to hold an O-Ring over the pin. Place a small dremel grinding bit in a drill press and then set the table to line up with the center of the pin whole in the adapters. All you need to do is spin the adapter around 360 degrees an the bit will make the groove. You will likely have to turn it a few times to get a deep enough groove, but then it only needs to be deep enough to hold the O-Ring in place. If you don't have a press, you can clamp the adapter in a vise and free hand it with a dremel. Hope this helps/makes any sense.
01-24-2008, 07:03 PM | #8 | |
I appreciate the advice, but the thread is actually about finding an adapter that will let me use the JP knuckles and battery packs..........the Integy adapters are just too short. | |
01-24-2008, 07:14 PM | #9 |
Sorry, got it after re-reading the first post.
01-24-2008, 07:31 PM | #10 |
you need the OFNA 30059 wheel adapters, they are 30mm, or just over 1.1" wider per side. They are 17mm and will fit onto the cvd's outer 8mm shaft. I have been running these for some time with success, however it is very wide, but with the narrowed axials you might be alright. Here is a link to a set on ebay |
01-26-2008, 11:37 AM | #11 | |
nosduj, do you have a width measurement of your rig that you could post? What rims & tires are you running? If I can't find something soon, I might just have to suck it up and try using Proline rims instead, and pony up for a set of 23mm adapters. Of course, then my search will be starting all over again...........lol | |
01-26-2008, 03:34 PM | #12 |
Pebble Pounder Join Date: Jan 2006 Location: Calgary Alberta Canada
Hey, I'm just wondering how far are you from the "metal super store"? It's down in south calgary I cant remember the address off the top of my head, but if you bought a section (some thing like 12" I would chip in for half) I could mill some adaptors up for you, I have the lathe and expertice to do such things and it shouldn't take more than an hour to do. I'm just putting that offer out there for you as it might be easyer to do that than to find the right part. Pm me and let me know. |
01-27-2008, 07:50 PM | #13 |
Thanx for the offer Brant, but I think I've decided to switch to a 23mm hub and proline rims. It's not what I was originally aiming for, but I think it'll work out better for me in the end. Anyone have any advice on 23mm adapters for CVD's? I was thinking maybe one of these: http://www3.towerhobbies.com/cgi-bin...?&I=LXLUD7&P=7 or http://www3.towerhobbies.com/cgi-bin...?&I=LXKGN6&P=7 |
01-27-2008, 09:31 PM | #14 |
Pebble Pounder Join Date: Feb 2007 Location: Gloucester
Look around The Crawler Store , RCP ,RC4WD. I'm running JP knuks , 1" wideners , Bender adapters , and Axle wheels . I'm in the process of changing over to TTR CVDs , and I'll be dropping back to 3/4 inch wideners . Should have plenty of room for the batteries . |
01-27-2008, 09:53 PM | #15 |
Quarry Creeper Join Date: Oct 2005 Location: SoCal
How close where the batteries with Team Integy 17mm Hubs 16mm Offset and Axial wheels. These adaptershttp://www3.towerhobbies.com/cgi-bin...?&I=LXTAZ5&P=7 I was about to order some but if they don't work, I'll save myself $20 |
01-28-2008, 04:38 PM | #16 | |
01-28-2008, 05:41 PM | #17 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
| I think you can use a set screw inside the CVD to hold the pin in. That is if I am talking about the right thing here.
01-28-2008, 07:38 PM | #18 |
| This is correct, they have a set screw that holds the pin in. BTW, does anyone know what size the Pins are that come with the CVDs? I need some spares.
