01-24-2008, 08:54 PM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| Need opinion 4 link
Anyone have this issue? After setting up my 4 link and I raise the left side tire it pulls the left front axle back, I'm not sure if this will be an issue or ? Here is my link set up top link to the standard place on top of axle lower link are connected just below the knuckle under the axle. |
01-24-2008, 08:58 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Move the upper link mount to the top hole in the knuckle. Then you need to move the lower links closer together at the frame, also you are way over flexed which will make just about any 4 link do funny stuff like that. Look at mine from the top, see the lowers, I have 0 axle steer or swing with this setup.
01-24-2008, 09:33 PM | #3 |
Thanks, I'll try that, I kinda think I am over flexing it a bit, wont the shocks stop some of the fexing also and help it not to axle steer?
01-24-2008, 09:48 PM | #4 |
Quarry Creeper Join Date: Jun 2006 Location: Folsom
I think your upper link mounts are loose also. I have some like those on a Gecko2 and if they loosen up the axle gets sloppy and over flexes.
01-25-2008, 07:33 AM | #5 |
Thanks guys ill try that tonight.
