Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Will I be within 2.2 width regulations with these rims???
Old 03-11-2008, 09:01 PM   #1
Default Will I be within 2.2 width regulations with these rims???
Will I be under the legal width if I use these rims?
these rims.. http://www.tcscrawlers.com/ON-SALE-3...2-p-16540.html
chino is offline   Reply With Quote
Old 03-11-2008, 09:25 PM   #2
Dream...Think...Create.
Nova's Ark's Avatar
Maybe. You definitely need to use the narrow wheel base wheels. I assume you are using these with stock clod stub axles. It could change depending on if you run CVD's. You need to put out a little more info to get a more specific answer.
Nova's Ark is offline   Reply With Quote
Old 03-11-2008, 09:34 PM   #3
Well for some reason I can not edit my post. The rims will be going on unmodifed Clod axles (dimension wise)
Old 03-11-2008, 09:42 PM   #4
If you run those Wheels with TTR CVD's you'll be over the 12.5in on Track Width. If you run those wheels with Stock Axle Shafts you will be about 12in on width. If you cut the outer bead off those wheels and run stock axle shafts. You should be around the 11.80in Track Width.
run2jeepn is online now   Reply With Quote
Old 03-11-2008, 09:50 PM   #5
Awesome, thats exactly the response I was hoping for. Thanks.
