Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: clod build help question
Old 03-20-2008, 08:51 PM   #1
Default clod build help question
hi everyone i am in the middle of building my first clod base crawler, and i am collecting parts and assembling i noticed that i do not have the metal brace that goes from the diff / trans to the end of the axle on the knuckle. do i need this part or do crawlers not use them? http://www3.towerhobbies.com/cgi-bin...?&I=LXGB68&P=X that is the link to the part on tower if i didn't make any sense.
zach318 is offline   Reply With Quote
Old 03-21-2008, 12:15 AM   #2
Integy makes a set that comes with servo mounts that are really nice I think. You should check them out, I think they are only $20.00 for the full set with hardware and all.
4mods is offline   Reply With Quote
Old 03-21-2008, 04:00 AM   #3
If you are planning on running the stock plastic axle tubes, you should definitely consider running those or the Integy ones. They provide support and prevents deflection of the axle tubes. They can also be used to mount servos, batteries, or speed controls.
jdmstuff is offline   Reply With Quote
Old 03-21-2008, 05:16 AM   #4
They are highly recommened. They give much needed support and places to mount batteries and Electronics.
run2jeepn is online now   Reply With Quote
Old 03-21-2008, 12:34 PM   #5
here is the Integy brace:
http://www3.towerhobbies.com/cgi-bin...?&I=LXSKC0&P=7
I got a set and they are pretty beefy, only thing I don't like is that they mount the servo a bit higher then necessary...
rcktpwrd is offline   Reply With Quote
Old 03-23-2008, 07:54 PM   #6
thanks for the help guys i will order the integy ones.
