Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Ride height...lost some droop but gained better flex...
Old 03-30-2008, 01:41 PM   #1
Question Ride height...lost some droop but gained better flex...
I don,t think the height will be a problem since the way I chopped the TLT chassis gives it very low CG...please share some opinion on this.
I was having an over articulation problem with the old setup but now the rig feels more stiff and ready to rock...
here is the old setup
I added my TLT shock springs on the inside of the Maxx stock springs it has given me less travel and I also mounted the shocks to a more upright stance,I was thinking of adding some length/height (for shock mount)to the chassis by bolting in some kind of extensions but this seems to work fine although I do loose a little droop...Click the image to open in full size.
please tell me what you think about this setup>>>>thanks!
TheHeadHunter is offline   Reply With Quote
Old 04-01-2008, 11:58 AM   #2
Default Nice!
Hi, I think your rig looks awesome! I really like your wheels and tires setup, can you help me? I would like to know what wheels, what tires, what wheel adaptors and did you change any axle shafts? If you can provide with the part numbers, that would really help me a lot! Thanks in advance!
Axis is offline   Reply With Quote
Old 04-03-2008, 09:06 AM   #3
http://www.tcscrawlers.com/Proline-R...0-p-16213.html
http://www.tcscrawlers.com/Axial-8-H...4-p-16475.html
http://www.tcscrawlers.com/Integy-17...N-p-16650.html
I haven't changed shafts yet ,its just the beginning for this one !
