07-28-2004, 11:04 AM | #1 |
Newbie Join Date: May 2004
| links
how thick should i make my links
07-28-2004, 12:06 PM | #2 |
| Re: links
I have found that 3/16" OD aluminum tube werks great for the uppers. For the lowers, slide a piece of 1/4" steel brake-line over it for super strength. Or just use 1/4" aluminum for the lowers. I buy the 3/16" tube with a 0.035" wall thickness from my LHS or Ace Hardware. This is the right size for a 6-32 NC tap so it is really easy. |
07-28-2004, 12:11 PM | #3 | |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: links Quote:
07-28-2004, 12:34 PM | #4 | |
| Re: links Quote:
I would love to see yer 1/2" steel links | |
07-28-2004, 10:34 PM | #5 |
Pebble Pounder Join Date: Jun 2004 Location: Alberta, Canada
| Re: links
Just use 1/4 rod and be done with it..for crawling they will never bend
07-28-2004, 11:55 PM | #6 | |
| Re: links Quote:
07-29-2004, 10:52 AM | #7 |
| Re: links
8O ...my links on the back are about 9 inches long and I have NEVER bent it, even the slightest bit.
07-29-2004, 11:16 AM | #8 | |
| Re: links Quote:
07-29-2004, 11:50 AM | #9 |
| Re: links
Yep...22 ich wheelbase..the things a beast... the only thing i have ever broken is a buntch of tube from the chassis and a couple ball ends.
07-29-2004, 12:33 PM | #10 |
Newbie Join Date: Jul 2004
| Re: links
I had some SS lower links made for me. 6" long with holes drilled in it for different shock mounting points, so far no damage. Only thing breaking are steering knuckles. I twisted up a rod end but that was because I hadn't threaded the set screw all the way into the rod end. :?
