Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: clod links
Old 05-28-2008, 11:13 AM   #1
Default clod links
i was wondering where i could find a good set of links for my clod
clod driver is offline   Reply With Quote
Old 05-28-2008, 11:43 AM   #2
RC4WD has a set of solid stainless steel links with aluminum ball ends. Check them out at www.rc4wd.com under "solid links" then "package deal".
MasterShake44 is offline   Reply With Quote
Old 05-28-2008, 12:58 PM   #3
you can make your own also
breitenbach14 is offline   Reply With Quote
Old 05-28-2008, 01:47 PM   #4
Good point!
Old 05-28-2008, 02:15 PM   #5
Location: where fear and common sense don't get in the way
Get yourself some 1/4x.49 K&S aluminum tube like this
http://www3.towerhobbies.com/cgi-bin...&I=LXS021&P=ML
Some 4-40 all thread
http://www3.towerhobbies.com/cgi-bin...&I=LXD871&P=ML
Some Traxxas rod ends
http://www3.towerhobbies.com/cgi-bin...?&I=LXJG69&P=7
and you can make all the links you will need.
jagg is offline   Reply With Quote
Old 05-28-2008, 02:23 PM   #6
RIGHT!!!
You can also stop at Home Depot and get some 6x32 threaded rod, and then at NAPA and some UNPAINTED 1/4" brake line - all of this about eightbucks cheap!
Then just the rod ends. I've made all my links this way - they're certainly not as strong as a solid link - but if you're on a budget or want to scratchbuild as much of your rig as possible this (imho) is the way to go.
The brakeline is great to have around for brazing projects too - it's what alot of people use when they make tube chassis.
Best of all, when it's 12:30am and the LHS is closed, you can still have links!
OldShovelhead is offline   Reply With Quote
Old 05-28-2008, 09:25 PM   #7
i have always made my own i just don't want skimp out on this buld
Old 05-28-2008, 09:33 PM   #8
We can custom make you a set using 6061 seamless tubing and Dubro Monster Duty plastic rod ends as well. We also have true carbon fiber links if the rig isn't going to see too many rocks. Those are typically used on our race chassis. Thanks!
CPE MT is offline   Reply With Quote
Old 05-28-2008, 09:42 PM   #9
Default clod links
i was looking at the links here but i dont know where to get them
Old 05-28-2008, 11:11 PM   #10
Those can be made just as easily as alum. or steel tube. Look in your phone book for plastic suppliers and get yourself some delrin or acetal rod. Those look like 3/8 inch. You can use 7/16 or even half inch if you want. Losi eight rod ends are a near perfect match for 3/8. Bore it, tap it, and use all thread or long set screws. I think xrc will make those for you too.
fatbastard is offline   Reply With Quote
Old 05-28-2008, 11:16 PM   #11
Yeah I made my first set of those for my super.
Just used a drill (for a lathe),a file, and drill bit. Put some screws in there and put Revo rod ends on it.
Speedyboy is offline   Reply With Quote
Old 05-28-2008, 11:24 PM   #12
Clods have Links.....
Old 05-29-2008, 12:01 AM   #13
yah we all don't run sticks
Old 05-29-2008, 12:03 AM   #14
thanks for all your help
Old 05-29-2008, 12:29 AM   #15
Give David a call over at xtreme Rc Hobbies. His been making links for sometime and same nice set ups.
Old 05-29-2008, 07:22 AM   #16
cartronicshn's Avatar
Yup David from insanerc comes to mind on the set i got from him for one of my supers, also Brett from CPE has some nice links and they can custom make them also.
cartronicshn is offline   Reply With Quote
Old 05-29-2008, 09:35 AM   #17
are they a good price if they r i might check it out
Old 05-30-2008, 02:54 PM   #18
The links in the pic look like carbon fiber arrow shafts. You can usually get some cheap arrows from a sporting goods store. Or if you are like me, grab your brothers broken arrows from his basement....... I have my stash for the super I'm building......
Mule is offline   Reply With Quote
Old 05-30-2008, 03:45 PM   #19
so are they sold as the shafts or the hole arrow
Old 05-30-2008, 04:01 PM   #20
The whole arrow.
Think of it this way, that's 36" usually of tubing and I think they sell for about $4.00 for the practice ones. I have some smaller ones I bought for the kids little bows and I think they were $2.50
