06-06-2008, 02:33 PM | #1 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
| thinking 2.2 build
I want to build a 2.2 clod,does anybody know if axial 2.2 beadlocks fit as they have a 12mm hex?.i will do a 12" wheel base tuber.
06-13-2008, 01:51 PM | #2 | |
Newbie Join Date: May 2007 Location: culver city
06-13-2008, 02:46 PM | #3 |
Yeah i did try my cr01 wheels and tires,the clod diff clearance is the same as the cr01.I need rims that move the tires in,? offset like you see on other 2.2 clods.A good idea though.Kool looking crawler andrew666
06-13-2008, 02:51 PM | #4 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Is this going to be a comp crawler or just a basher? If it's a comp crawler, you are looking for bead locks to pull the tires into the axle. You do not want to get any wider than you absolutely have to.
06-14-2008, 11:59 AM | #5 |
Yeah i was thinking comp crawler with bead locks,with the cr01 wheels on the clod axles it measured 12" wide where the cr01 measured 11" wide to outside of the tires.
06-14-2008, 06:47 PM | #6 |
Quarry Creeper Join Date: Mar 2006 Location: Scappoose, OR
get some Mayhem beadlocks you can get your with down below 11" if i'm not mistaken for around 95 bucks or so, or createacrawler has some wheels as well but they are something like 150-170
06-15-2008, 12:17 PM | #7 |
thanks bulzeye,ill look in to those rims.
