Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: wheel adapters
Old 07-14-2008, 02:05 AM   #1
Default wheel adapters
jus wondering if anybody out there has tried to fab up a home made wheel adapter for a clod? if so what were the things used to make them and how'd you do it.
bradahb is offline   Reply With Quote
Old 07-14-2008, 12:57 PM   #2
For what they cost it wouldnt be worth it,at the bottom of the world(new zealand)they are $60 for a set of 4,all the machining etc not worth the time.
vipxj is offline   Reply With Quote
Old 07-15-2008, 04:54 PM   #3
I would buy them as well...search the vendors here or on ebay...delrin ones are lighter but aluminum will hold up to more abuse....stay away from the ones where you need to drill holes in your wheels to add 5 screws, they weaken the wheel and I have broken wheels with them...
1rcmonster is offline   Reply With Quote
Old 07-15-2008, 04:56 PM   #4
What wheel are you trying to mount to the Clod?
Old 07-16-2008, 05:39 PM   #5
as of right now im undecided on if i want to go with 2.2's or bigger. i was just wondering if there is a universal adapter that will go from 14 mm to a 23 mm .if so where can i get it?
Old 07-17-2008, 01:34 AM   #6
i used wheels with a 14mm hex and wrapped a piece of brass around the 12mm tamiya adapters. fits nice and snug.
as for adapters Integy makes a bunch for just about any size.
Tucker is offline   Reply With Quote
Old 07-17-2008, 03:24 AM   #7
you got any pics on how you wrapped the pieces of brass around 12mm hex? just getting curious on how u did it.
Old 07-17-2008, 05:44 PM   #8
i flattened some brass tubing and laid an end on one of the flats of the hex and held it with vice grips and just worked it around with another pair of pliers making sure the corners were tight. it should fit really snug in the wheel or it may work its self out over time. a spot of CA couldn't hurt.
another thing is that there is no off set for the wheels with this, i narrowed my rims so i dont know if they will fit and still have clearance.
if you need pics i can take some.
hopes this helps
Old 07-17-2008, 06:04 PM   #9
PapaGriz Yo
Grizzly4x4's Avatar
From the Clod FAQ sticky.
Originally Posted by Grizzly4x4 View Post
How do I adapt wheels to the Clod Axles?
Clod axles have a 12mm hex, many of the vendors sell hex adapters and wideners to allow you to run wheels with 12mm hex, 14mm hex, 17mm hex, and 23mm hex.
TMaxx, EMaxx, Savage, etc wheels are 14mm hex so you will need a 12 to 14 mm adapter.
Proline 40 series wheels can be found in 14mm hex and 23mm hex.
Axial 40 series wheels use a 17mm hex.
Maxximizer wheels come with 14mm hex or 17mm hex.
MAXX wheels mounted to clod without adapters.
Info on adapters and wideners
http://www.crawfordperformanceengine...216150896.7248
http://www.tcscrawlers.com/Wheel-Wid...-p-1-c-25.html
Grizzly4x4 is offline   Reply With Quote
Old 07-18-2008, 12:24 AM   #10
yup! the pics would be cool. if its not going to be any trouble. just want to see exactly how you did it. dis might be something i could pass down to my brother , he's also building clod and cant figure out what size wheels he'ii be going with too. just so you know dis is our first clod build, not to be cheap on the build but just something for now and so we can test it out until we get serious with it. so thanks for the help man.
Old 07-18-2008, 10:02 PM   #11
went a little overboard with this, and the upload shrank it down alittle. hope it helps
Old 07-18-2008, 10:09 PM   #12
just to clarify, it shrunk it a ton.
TUCKER'S WHEEL ADAPTERS
brought to you by Tucker
1. WRONG!!!
2. i used brass tube cuz its easier than cutting strips of sheet
3. make sure your comfortable, this may take 15 minutes
4. round to flat
5. hold on a flat with vice grips but not to tight on the splines
6. bend by hand and sharpen with pliers
7. few more times
8. TA-DA!!!! cut off extra
9. tack glue in rim
10. put in the hex and install tire on car
11. install car on rocks
12. HAPPY CRAWLING!!!!
Old 07-24-2008, 11:59 AM   #13
hey thanks man i try your method.
