09-12-2008, 10:37 PM | #1 |
Newbie Join Date: Apr 2008 Location: North Pole
| axle grease?...
What grease should I use in the axle? Everything is dry. Can I use marine grease through all the axle? Thanks! |
09-12-2008, 10:39 PM | #2 |
I like the Gear Jelly by Rocksmith in my Clod axles...
09-12-2008, 10:52 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
I have been using a tub of the cheap multipurpose wheel beaing grease from Walmart for years without issue. Also used the marine grease when things had a chance of getting wet. Any grease is fine as long as your using it. I wouldn't recommend scooping it by spoon into the axle. Just a little here and there on the gear teeth is good.
09-12-2008, 10:54 PM | #4 |
Do I have to use a different grease in the diff or any other part in the axle? Thanks guys! |
09-12-2008, 10:58 PM | #5 |
No diffs are of open design. If your crawling with them I would either buy lockers or epoxy them. |
09-13-2008, 01:56 AM | #6 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
| same here i use the same grease to do the front bearings in my car. some people say it will weaken the plastic but ive used it for 2 decades with no problems.
09-13-2008, 07:35 AM | #7 |
09-13-2008, 11:06 AM | #8 |
Quarry Creeper Join Date: Nov 2007 Location: Cincinnati
