10-31-2008, 07:06 AM | #1 |
Pebble Pounder Join Date: May 2008 Location: Mobile, AL
| Integy 23mm adapters compatable with CVD's?
Hey guys, I'm getting ready to order up some parts to start a super build here in the next week or two. I've been looking around at what parts to buy and I'm going for the CVD's for sure, but will the Integy 23mm adapter work with these? If not what kinda mods would I have to do to make them fit? I realize the CVD's are 8mm vs the stock being 5 or 6mm? so I would prob. have to drill them out right? Thanks, Jake |
11-01-2008, 10:33 AM | #2 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
Yes, the Integy 23mm adpaters can be used with the TTR CVDs, but as you said, they will need to be drilled out to slide over the stub shaft of the CVDs. On my axles, I did just that. I bought an 8mm drill bit and then chucked the 23mm adpaters up in a lathe at work, to be sure they would be bored out on center. Everything went together, as normal. No other mods needed. Slip the adapters onto the CVD stub shafts, insert the pin, followed by the rubber O-ring to hold the pin in place, and you are ready to roll. |
11-01-2008, 05:55 PM | #3 |
Sweet, thanks for the reply... I don't have a lathe so I'll have to use a drill press, lol >< Thanks again Jake |
