11-19-2008, 12:53 AM | #1 |
Quarry Creeper Join Date: Dec 2007 Location: stevens point
| intergy adj. motor mount JUNK
I got some adj. intergy motor mounts and figured out they will not work with out modding them. The screw hole to bolt it to the motor need to be counter sunk so it will fit flat up to the trans and there is no hardware at all. Junk very bummed :-(and will buy the cpe kit next. Probubly last intergy part I buy because if they screw up a simple adapter plate then the rest can't be far behind.
11-19-2008, 06:50 AM | #2 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
WHAT SIZE PINIONS ARE YOU RUNNING? I HAD TO MODIFY MY CPE ONES FOR MINE. IM RUNNING A 6T AND A 7T. IT SAID IT COULD HANDLE THE 6T BUT I HAD TO SHAVE IT DOWN SO I COULD GET A GOOD MESH. SO YOU MITE STILL HAVE TO MODIFY THEM EVEN IF YOU GET THE NEW ONES. GOOD LUCK THOUGH! |
11-19-2008, 07:34 AM | #3 |
you cant beat the CPE mounts
11-19-2008, 07:35 AM | #4 |
Rock Stacker Join Date: Oct 2008 Location: Fairmont
i personally have had nothing but issues with anything that integy makes. i dont know what kind of metal they use, but its junk. i will only buy stuff from brett at CPE now.
11-19-2008, 05:37 PM | #5 | |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
The Integy ones are way too thick to work, even if all the hardware was included unless you were using the special long pinions. Thanks! | |
11-19-2008, 07:06 PM | #6 |
I Just Had To Grind It Down Some To Get It To Slide Far Enuf To Mesh Correctly. No Biggie! I Wouldnt Be Able To Get A Pic Unless I Took It Apart Again. (i Finally Got It Right) Cpe: By The Way.... Thanks For All The Help Today On The Servo Mount Issue! Your Customer Service Is Top Notch! |
11-19-2008, 08:06 PM | #7 |
So the side-to-side adjustment was fine but the gear wasn't long enough to mesh fully with the gear (depth of pinion on motor shaft)?
11-19-2008, 08:08 PM | #8 |
It Was The Side To Side That Didnt Have Enough Space To Get The Pinion Close Enough To The Gear Inside The Case.
11-20-2008, 12:08 AM | #9 |
| cpe
I ordered a set of cpe from you brett today last part needed for my super build and can't wait to hit the rocks. I'm running 7 tooth so I should be fine. My super is a claw so I guess I'm cpe all the way.
