01-08-2009, 10:52 AM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: morristown
| motor
what is a goods turn motor to run with the stock clod 13t pinion
01-08-2009, 11:56 AM | #2 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
my boy runs the protocall 55t with his stock pinions. or if you want it a lil slower run a 65t or a 75t
01-08-2009, 01:25 PM | #3 |
i whant to be arond 90:1 gear ratio
01-08-2009, 01:42 PM | #4 |
Newbie Join Date: Dec 2008 Location: Bay Area
i currently run the novak 55t motors and i like them alot
01-08-2009, 03:00 PM | #5 |
does any one now the gear ratio of the 55t 65t 75t
01-08-2009, 03:11 PM | #6 |
Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
motors dont have "ratios" they have rpms,amp rateings and also rpm/volt. Unless....... the motor has some sort of gearhead then the motor has a rpm with a geared ratio of xxx |
01-08-2009, 03:54 PM | #7 |
i know. i whant to know the final gear ratio going to the ground
01-08-2009, 04:37 PM | #8 |
Newbie Join Date: Dec 2008 Location: Gilbert
I liked my 75t with sock gearing.
01-09-2009, 02:06 PM | #9 |
i am going between a 55t and 65t what do you guy prefer.
01-10-2009, 02:23 PM | #10 |
i am thinking of a 65t but will i still have some wheel speed
01-10-2009, 09:08 PM | #11 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
a 55 will cut the stock speed by about half.a 65 even slower.i tried some 45s had some speed but was a little gutless.
01-10-2009, 11:52 PM | #12 |
ok so will the 65t be abel to tern the stock tires prity will in the rocks
01-12-2009, 02:48 PM | #13 |
does any one know if a 65t motor will turn the stock clod tires in rocks or no
01-12-2009, 10:39 PM | #14 |
Quarry Creeper Join Date: Jun 2007 Location: Calgary, Alberta
01-13-2009, 04:43 PM | #15 |
will it turn them if they are in a bind
01-13-2009, 06:58 PM | #16 |
Pebble Pounder Join Date: May 2007 Location: No Where
I run stock gearing 14.4v and 65t. My clod goes about 8-10mph which is still fast enough for some bashing and has plenty of power. Personally i think its about a perfect ballance between speed and power. If i were doing more crawling though i would want to slow it down a little.
01-13-2009, 07:40 PM | #17 |
thanks will it still have plenty of power by runing 7.2v stick pack
01-13-2009, 07:45 PM | #18 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
01-14-2009, 07:47 AM | #19 |
ok how do you get 14.4v
01-14-2009, 07:58 AM | #20 |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
More battery cells in custom packs. You need to make sure your ESC(s) can take 14.4v though else lots of smoke! |
