12-27-2008, 07:32 PM | #1 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
| do you need axle stiffeners?
when running aluminum axle shafts do you still need to use the diagonal axle stiffeners? is there any strength gain or loss by or by not using them?
12-27-2008, 08:21 PM | #2 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
If you run the aluminum axle tubes, but still use the stock plastic case, leaving off the angled braces can transfer a lot of stress through the 4 bolts mounting the tube to the case.
12-28-2008, 07:53 AM | #3 |
I havent had any problems with my setup (of course, I am only running 2.2's): |
12-28-2008, 01:22 PM | #4 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
I'd still run the braces, or brace. (depends if you have a servo mount that replaces the one brace) You could possibily break the plastic gearcase housing, but I imagine it would hold up reasonably well, as long is didn't get knocked around really hard, like taking a tumble down a hill. I have full metal cases and I still run the braces. Sometimes they are handy for servo mounts and electronic/battery mounting plates.
01-16-2009, 10:38 PM | #5 | |
Newbie Join Date: Nov 2008 Location: Indianapolis
Agree. I would run them to be safe, otherwise you might be replacing the center pumpkin | |
