01-19-2009, 01:33 PM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: Salford, UK
| How to make clod wider (other than axle extenders)
How can i make the clod wider other than axle extenders, is there any tube/shaft convertions or extended hubs or anythin like that? Craig |
01-19-2009, 01:38 PM | #2 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
As far as I know the only marketed products to widen a clod are wheel/ax;e extenders. If you know someone that can weld aluminum you might be able to mod a set of aluminum axle tubes, but that would leave you axle shafts that are too short...
01-19-2009, 03:50 PM | #3 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
Hello, Hot Racing makes some long tubes for the clod axles. They would add 15 mm on each side. Here you can have a look on them: http://www.hot-racing.com/?partnumber=CB20EL08&c=38 Greatings from germany Frank |
01-19-2009, 03:53 PM | #4 |
But the Shafts break to easy... not worth it.
01-19-2009, 04:07 PM | #5 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
You can add a 1/4" per side by using the TXT stub axles, drive hubs, and wheels. There are some aluminum wheels made with full offset, with will push the wheels out further as well. |
01-21-2009, 06:24 AM | #6 |
Cheers, i could try those longer axle tubes and if the axles break maybe look into some tougher ones beeing made up that would help, it does say that only their knuckles work with it though :( 15mm either side is an improovement but still not really enough for my project, m trying to make a large scale crawler. Craig |
01-21-2009, 09:32 PM | #7 |
Rock Stacker Join Date: Mar 2006 Location: montrose co
those hot racing axles are interesting pieces. any one run these, they could eliminate my integy wideners that keep working loose. i've wanted some aluminum tubes anyway.
01-21-2009, 09:39 PM | #8 |
Quarry Creeper Join Date: Mar 2006 Location: Gresham
How wide is a stock clod axle with stock tires and wheels from outside of wheel to outside of wheel? my clod axles with my wheels Are between 15 and 16 inches wide I use something like these not sure which ones I have tho, then not sure what beadlocks I got, I have never had a problem with anything loosening up on me http://www.rcrockcrawling.com/produc...8f313b1d563566 Last edited by Rc_Kid; 01-21-2009 at 10:24 PM. |
