02-04-2009, 08:40 AM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
| Project: Low Budget Super
Im starting with a relativly low $600 budget (up from my original plan of $500) Clod axles: $75 shipped (forsale section) Integy axle Tubes: $34 a set (LHS) Integy Knuckles: $28 a set (LHS) Stick Backbone: $27 (Mcmaster) 2024 alloy 1/2"x.095 wall Heims: $6 x2 (Mcmaster) 3/8 bolts: $1 total (Ace) 4-40 bolts: $5 per 100 (Fastenal) 4-40 nuts $1.50 per 100 (Fastenal) 2-55t lathes: from existing trucks (normal price $19 @ LHS) dx6: From my crashing of airplanes about 2 yrs ago (ebay value $60) dx6 regulator: $15 (dimensionengineering.com) dx6 spring mod: $0.50 for spring (ace) Dubro 6-32: $1 each 8 needed (vendor section) Brakeline links for now: $3.40 for 5' (Northern autoparts) will be changed to delrin in the future. 6-32 threaded rod: $1.82 for 3' (HomeDepot) Maxx Big Bores: $8.53 each x2 ($68.24 for 8 rcslot.com) misc 1/4" aluminum for shock mounts: free from friend 1/2"x1/4"#4 spacers: $0.27 (Mcmaster) Switches for DIG: $2 x2 (Frys Electronics) 2 sidewinders: $83.07 each (rcslot.com) Castle Bec: $24.56 (rcslot.com) Total so far: $486.52 I have enough material to make 2 backbones so I am making 1 shorter for turning courses and 1 longer for climbs like at Nationals. My Budget is looking in jeapordy but, I plan to do some money saving such as reusing the BEC and Mamba Maxx from my current super class truck (savings of $107.63). I also wont be using a dedicated battery for this project, I will reuse one from another truck. initial layout to get an idea how it will look: After Integy parts installed, Links made, backbone drilled/tapped. Not shown is the jig I made, its basicly 2 pieces of aluminum L (pictures on request) As you can see, I decided not to clock the motors very much. I didnt like the steering angles that it created. I still need to add 2 steer servos to the cost list and a dig servo. I am waiting for the new Proline super class tires to be released before I make a call on that. Last edited by jetboat; 02-04-2009 at 02:50 PM. |
02-04-2009, 09:59 AM | #2 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
What are the new Pro-Line tires going to be? Besides Moabs, it's about time they released something for the supers. Chisels?
02-04-2009, 10:02 AM | #3 |
Unknown to me at this point... thats why Im waiting.
02-04-2009, 05:28 PM | #4 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
What is the jig and whats it used for? I might have some of that alum L laying around somewhere |
02-04-2009, 06:06 PM | #5 |
my 08 TXRCRCA state champ rig cost less than that. but killer rig man. youll love it. |
02-07-2009, 10:44 PM | #6 |
any progress? I just bought my axles today
02-08-2009, 05:46 AM | #7 |
I see you haven't gotten any Servo's yet. I've got the best Budget Super Servo's you can ask for. Over 330oz for $30 bucks... Full Metal gears too... |
02-08-2009, 07:12 AM | #8 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
02-08-2009, 07:50 AM | #9 |
02-08-2009, 01:08 PM | #10 |
I have made some progress but, its been designing servo mounts etc... all cad work.
02-08-2009, 01:11 PM | #11 |
Are you going to use 4 shocks instead of 2? I think it would be a good idea.
02-08-2009, 01:14 PM | #12 |
02-08-2009, 01:22 PM | #13 |
So that it dampens on both sides. The way they are setup it does some weird things, I have run them 12.5", 16", and 18". And I do not like the way it flops around using 2 shocks. I think it would be more predictable using 4. A guy here in CO made one using 4 savage shocks, that rig killed.
02-08-2009, 01:26 PM | #14 |
Ive been running a 2.2 for a couple months now and I love it... very predictable. Properly setup, I find that it doesnt flop around either direction... 1 direction the front shock does the work, the other the rear.
02-08-2009, 01:31 PM | #15 |
I never could, and I spent ALOT of time on them. Between the axle steer and the flop, I gave up and went for a 4-link setup. Good luck with your build and keep up the creativity, long live the super class! |
02-08-2009, 04:54 PM | #16 |
made a few parts... 2 lower shock mounts and 2 BTA servo mounts. Im not sure if Ill be able to use the rear servo mount though because of the way the stick shocks mount. |
02-09-2009, 06:14 AM | #17 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
What angle did you bend your links? I was thinking about making a set of bent links for my stick. Carl |
02-09-2009, 07:53 AM | #18 |
02-10-2009, 06:04 AM | #19 |
I did a little work on the lower shock mounts and figured out the uppers. |
02-15-2009, 11:00 AM | #20 |
I made some more progress... The upper shock mounts are made and amazingly give exactly the articulation I wanted. |
