Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: pinion pitch
Old 02-09-2009, 09:49 PM   #1
Default pinion pitch
What is the difference between pinions with a 32p and a 48p?
lud98r is offline   Reply With Quote
Old 02-09-2009, 11:23 PM   #2
The profile of the teeth are different. They are not interchangeable.
Without going to crazy and writing about book about what pitch is, all you really need to know is that pitch is a measurement of the angle of the teeth, in relationship to the point at which the teeth mesh with another gear of the same kind. The smaller the number, the more coarse, stronger, and noisier the teeth are. 48 pitch is finer then 32 pitch, but because the teeth are smaller, you can get a wider range of gear ratios using it.
Espeefan is offline   Reply With Quote
Old 02-11-2009, 01:40 AM   #3
thanks for the insight. Greatly appreciated!
Old 02-11-2009, 11:53 AM   #4
If its clod,its 32 pitch and not changable.
smokin0137 is offline   Reply With Quote
Old 02-11-2009, 09:49 PM   #5
Ha. The email notification says you typed 48 pitch, but you must have edited the reply, after. I was going to bust your chops, and now I can't!
