02-18-2009, 08:47 AM | #1 |
Newbie Join Date: Feb 2009 Location: North Port
| To Clod or not to Clod? Ok I am new to the Crawler world, but have been pretty much racing RC’s for the last 6 years. I have an E-Maxx I am contemplating changing over, but I kind of want something that I can how do you say mod the crap out of it! I have been looking at the AX10, the Venom, don’t get me wrong they look great, but I want something that is a lil more beefier. And with all the high modded crawlers I have seen, the one that has stuck in my mind is the clod. Seems that a lot of them use the clods axels. Now to my question, what are the benefits of going to a clod and any cons if there are any? |
02-18-2009, 08:57 AM | #2 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
There's more aftermarket parts for the Clodbuster than just about any other kit. The axles are really beefy in stock form and can be made bulletproof as your budget allows. Cons may be they're a little wide to run as a standard 2.2 rig. Different tubes, knuckles, and wheels are available to bring their width down considerably though. |
02-18-2009, 08:57 AM | #3 |
Quarry Creeper Join Date: Nov 2008 Location: London UK
You want beefy, convert your e-maxx. |
02-18-2009, 09:02 AM | #4 | |
02-18-2009, 09:02 AM | #5 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
If you are going to build a super style truck IMHO there is nothing better than clod axles. |
02-18-2009, 09:30 AM | #6 |
Pebble Pounder Join Date: Nov 2008 Location: Virginia Beach
Clod axles all the way. The number of available replacement and aluminum, hop up parts alone make this any easy choice. There is also a great tech article stickied at the top of the page on how to build solid clod axles. Welcome to RCC.
02-18-2009, 09:31 AM | #7 |
| Currently working on an idea to mount a pivot point between the chassis plate and the bulkheads. This would raise the chassis itself and allow the chassis to twist. Basically it would look like an anglecoming from the bottom of the chassis with a shaft 90 degrees heading straight towards the bulkheads. another angle mounted on the bulkhead aloowing the bulkhead angle to rotate on the shaft. Going to try this with wood and get the diminsions correct and have a friend make them out of aluminum.
02-18-2009, 09:42 AM | #8 |
| Thanks ! ! ! Every pic or awesom Crawler that i have run acrossed, it either said modified Clod or Clod axels. I have seen alot of different chassis and for some reason, realistically the sheer size of the Clod compared to other crawlers is what appeals to me. most of the guys in the area run the AX10 or Venom, but then this old guy comes up and tosses out this crawler and drives up the hill of rocks like it was nothing. and whaen you ask him what it is, he says it is a clod.
02-18-2009, 10:45 AM | #9 |
So you are looking to build a super or a smaller 2.2 crawler? either way you can't go wrong with clod axles.
02-21-2009, 07:51 PM | #10 |
RCC Addict Join Date: Nov 2008 Location: J-Braaaapin It Through Gate 10
| I've had my clod crawler for 4 years and I have never broke an axle. I would say if your going to build a super then i'd say 100% clod axles JRock Team Low Elevation Rock Krawlers 'Team L E R K' CRAWLIN CALI |
02-23-2009, 03:12 PM | #11 |
Quarry Creeper Join Date: Dec 2008 Location: So.Lake Tahoe,Ca
I would go clod.But they are not bullet proof.I broke my first axel in the snow about 3 days ago.Not the plastic axel tube,but the steel axel itself.Twisted it in two.Guesing I have to much torque.Wish I had a pic.
02-27-2009, 10:45 PM | #12 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
